Hey everyone,
I've been hunting aroung for a N/A R34 with the factory Altia aero kit, i was just wondering what are some tell-tale signs that it's a genuine plastic kit and a fibreglass copy?
Here's the kit in question
Thanks in advance,
Danny
The easiet way to tell the difference is the finish. Factory plastic will be smoother both outside and inside, fibreglass will normally be a little wavy and rougher on the inside or back of the kit.
Actually the plastic will be more flexable, if the kits off the car it makes it easier to tell as fibreglass will be heavier and thicker too. Not so much by running your hand over the painted surface, but by standing back and seeing if the kit looks wavy.
as mentioned the fiberglass kit will be rough on the inside.. the plastic, being moulded will hav alot smoother wall.. the plastic will be alot more flexible, should bend easily and bend back into shape..
Hahaha, by far the best method. One thing as well, is it true you're able to tell if you're factory aero is from the factory by getting your VIN "fasted"? I'm planning to import from Japan and i want to be sure i'm not buying a car with a copy fiberglass kit.
Cheers,
Danny
no one copies the altia kit.... no one. lol, it'd be kinda silly, esp when the factory option was so cheap compared to aftermarket according to the catalog.
if the r34 has an altia option kit on it, then its most probably genuine. there's plenty of genuine ones going cheap, and most of them have had them since day 1.
fibreglass kits are usually unpainted on the inside, a photo of the inside of the bumper will tell you pretty easily what it is.
failing that, just kick it. if it's fibreglass... run. if not, buy.
wut
http://cgi.ebay.com.au/Brand-new-Nismo-fro...%3A1|240%3A1318
we're talking about a car sitting in japan, not your usual habib spec chinese bodykit special r34 in australia.
i should qualify that by saying in japan it'd be cheaper to get an original factoy kit than a fibreglass knockoff.
Might not be a 100% certain method of telling but notice the side grilles of the one in your photo, they are a black factory looking material. Alot of copies dont come with that like the copy bar Mr Oizo posted.
Edited by MintR33
post-57849-1238972054_thumb.jpgr OIZO is spot on again
Here are pics of my genuine factory fitted kit - note: bonnet is not fully closed as just did oil and filter change, and car has not been washed for about 3 months - its always garaged - the key point to note is that area with the word SKYLINE imprinted (the lower front centre section) is always black/gray colour from factory - if car has front bar all same colour likely it has been modded or reprayed due to accident damage
Thanks mate, i also to a small extent noticed that (not with a concrete knowledge) but yes i did recognise on all the altia kits i have seen in real life. I did manage to get a good idea between a altia kit and a fibreglass uras kit at Top Secret Imports, the plastic was a little more rigid and much thicker than the uras one.
Also, referring to the "skyline" part in the middle, is that like a different plastic to the rest of the front bar? Like a raw-unpainted plastic center piece?
Cheers again guys,
Danny
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
