Hey guys,
Got an r34, have spent the last few hours searching with no results so I am creating a new topic.
Firstly, I love the look of all 4 taillights on my r34 lighting up. Is there any way i can rewire the lights so when the brakes are applied all 4 lights, light up?? I have seen this done before and would love a guide, or any help in how I can go about doing this.
Secondly, I Installed a new headunit two weeks ago, and then last week pulled the console out again, to re paint over the factory centre console paint. Both of these times i scratched the outter centre console pretty badly. (around the centre console) im sure you all know where I mean as looking through pictures of other 34's They all seem to be scratched. How do i go about fixing this?? Is there anyway I can retrim/paint/cover this?? what is everyones opinion on how to go about fixing this?
Thanks for reading,
Any help/opinions at all will be greatly appreciated.
Nathan.
Hey guys,
Thanks for reading,
Nathan.
as far as i can tell you cant fix the scratches, my only suggestion is to have it re-trimmed if it bothers you that badly, that or buy new trim pieces that are un-scratched, unfortunatly not a lot of options
What could it be retrimmed with? I'm not sure what the material actually is?
What do you think these pieces are worth in decent condition?
wouldnt have a clue, considered buying some and having a go at re-trimming them myself with a nice material in a colour to match the rest of the interior.
Try Nisswreck
Rush how could you retrim it considering its like a plastic??
Nuffsaid have you got any info on how to do it at all?
a materail/fabric glue spread evently over the surface should hold the material in place nicely, let it dry for a while and put it back in the car
I believe the plastic surround the whole area ,you can order it from Nissan , not sure on the price, i know Vic member Ashneel is looking into this exact thing as well, i have asked him to get me a price as well.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
