Modifying The R35
SlipR35
 Share
Long time reader, first time posting. Tried searching the forums but couldn't find anything specifc on whether owners of the R35's plan on doing any mods when they get them (plenty of discussions about warranty etc). If so it would be interesting to see what equipment has been purchased / what mods are going to be carried out.
Obviously there are owners who don't want to void warranty etc but there are also those of us for whom warranty is not the be all and end all. To start the ball rolling the following equipment will be installed on my car when it arrives in June:
  • 5Zigen turbo downpipes, Y pipe and Spec Tune exhaust
  • K&N air filter
  • HKS SSBOV kit
  • AP Racing two piece front and rear rotors
  • Ferodo DS1.11 brake pads
  • TR1 Stainless Steel braided brake lines
  • AccessPORT ECU
  • HKS EVC 6
  • Cobb tuning Anti sway bars
  • Eibach spring kit
  • AMS crank pulley
I've bought the car as a track car so not for daily use etc. Would be interested to see who else is going to mod their R35.
Cheers
Slip.
if it's a track car there are a few other things you should really consider:
1. trans and engine oil cooler upgrades. the stock cooling system will get too hot after maybe 6 laps or so. if you want to run more than that in a session, you'll need to upgrade the cooling, it's a good idea anyway.
2. paddles that move with the steering wheel (MCR carbon paddle kit). it's a bit awkward (and dangerous) needing a gear mid corner and having to take your hand off the wheel to grab a gear.
3. race seat (good to save some weight over the stock seats and of course greatly improve the on-track driving. add a harness to that too.
4. cage. this one is not so neccessary if you just want to do sprints and track days, but worth thinking about. R35s are a very fast car, and very heavy too.
I would put this gear ahead of the bov kit, evc6 and the crank pulley. also think about some track wheels and tyres too.
I need to keep my car within CAMS 2D specs for NSW club based Sprints, so mods will be relatively lightweight.
1. Tyres (295 RE55's all round) on 18" Enkei 18x10's
2. Midpipe
3. Willall tranny fluid and possibly cooler
4. Harness bar + harness
5. AP front rotors and uprated pads + fluid
Unfortunately i need to run the factory tune on the circuit (2D rules).
I might try the AccessPort for the street, strip and valet mode though.
Thanks Beer Baron,
I have a new set of Recaro's for the vehicle already and am looking into the cage side of things to see who can do one. I agree with your comments re the paddles, I have the MCR ones on order from the States but am waiting to receive them.
I saw that Willall Racing do the transmission intercooler upgrade, I'll have a chat to them about the oil cooler upgrade as well and get them to do both at the same time if this can be sourced.
Cheers
Slip.
Edited by SlipR35
Thanks Beer Baron,
Cheers
Slip.
have a look at giant's R35. he had a lovely cage built for that. i drove it at oran park gp on the weekend and it was lovely to drive. very easy to steer on the throttle and even though the chassis is pretty good to start with the cage does help, and of course adds to the safety. his has been retuned too with more boost etc and runs very nicely. the only thing you need to do is keep one eye on temps of trans and engine oil.
the biggest improver to driving feel would be:
seat and harness
wheel and moveable paddles
those things transform the way you can drive the car.
Na but it is the new small mini version. I tested it out last night and it worked perfectly! :(
It's the new lightened e-tag? I heard it was good for an extra second at the Nurburgring.
  • K&N air filter
  • HKS SSBOV kit
  • AccessPORT ECU
  • HKS EVC 6
  • Eibach spring kit
  • AMS crank pulley
Cheers
Slip.
First mods should be a Y-Pipe and the Cobb ECU and probably a boost controller because even with the latest maps some people complain about issues with Cobb's boost control. The next best value for money mod is the wastegate actuators swap.
Your Australian spec GT-R will have stiffened brake lines anyway, not sure brake lines are needed. Brake pads and some aftermarket slotted rotors for is all you need for the brakes.
BOVs? Why would you bother... Unless you're already buying the GT570 kit which comes with them there's no reason to go out and buy these on purpose.
With the seriesII suspension, spring kits aren't really doing anything for you unless you just want to lower it and already standard ride height is low. They weren't designed with the series II suspension in mind. See what comes out over the next few months in terms of springs but probably not worth doing.
Crank pulley? I wouldn't.
K&N Filters? Probably fine to replace the stock ones after the run in period with these but dont expect any gains.
Might be the wrong place to ask, and forgive me for asking a question that has probably already been covered, but does anyone know if the R35 can be switched to rear wheel drive only easily?
I was sure that it was said somewhere before but bugger me if I can find it.???
Cheers.
Well anyone interested in getting a Cobb should know we can now do a custom tune for them :sick:
The base tunes with the units are only designed for 96RON fuel so they'll work ok but could be improved. But we got the full Cobb Pro tuning software during the week.
Like others have said I reckon a Cobb + Midpipe is about where you'd want to be at if you are keen on modding your R35 as the most sensible place to start.
Oh - and rotors/pads. That way you can put your stock ones back on before you go back to Nissan in "new" condition and not be flogged with a $10K replacement.
Cheers.
You drop the return driveshaft from the transfer case.
It's not a simple fuse pull.
The Supercar Club guys came around with their new Gunmetal JDM GT-R tonight care of Beer Baron and we did a quick Cobb treatment on it to get rid of the speed limitter before it goes to Phillip Island tomorrow. Good little toy those Cobbs.
We also had a Willall Midpipe which we put on tonight and as a free pulg to Martin here it was a beautiful fit, made a HUGE improvement to external noise but internally (at least with the windows up) there was bugger all marked difference in noise and had no noticable drone on either the freeway or around the normal streets. The only real time you could hear the difference from behind the wheel was on the big down-shifts as then you could really hear the bark. Although driving with the windows down you can definitely hear it.
But thumbs up for a great mod to get. Easy to install (took 15mins on my gargage floor) and for the $$$ I can see no reason why you'd get a more expensive Jap one. And its definitely a major improvent over the stock system.
Well anyone interested in getting a Cobb should know we can now do a custom tune for them :banana:
Do you sell the Cobb tuner itself and is it in stock? If so could you PM me a price? Cheers!
I would guess you would have to do something with slip sensors also if you were going to use it for Drifting?
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
