I know there's a thread where all the A31 people have been posting their drifting setups but would anyone happen to know the factory settings that Nissan would have you use, or at least some decent settings for normal road use. Should I just use R32 GTS4 settings?
Oh BTW it's one of the 4WD A31s if that makes a difference :)
https://www.sau.com.au/forums/topic/263861-a31-alignment-settings/
  • 3 weeks later...
Turned out that the company that makes the alignment machine actually have settings for the Cefiro, and they're slightly different from the Skyline.
This scan should show the valid ranges, and also what a crap job the garage did at aligning my car. It handles worse than when I took it in.
Settings may be different if you have an RWD Cefiro. In fact they almost certainly are due to the different suspension design.
Any idea how to fix the front caster and rear toe? Also any cheap way to adjust the front camber as the current level of camber is preventing me from lowering the car :blink:
Edited by Lum
Any idea how to fix the front caster and rear toe? Also any cheap way to adjust the front camber as the current level of camber is preventing me from lowering the car :wub:
There should be some camber bushes available through whiteline ........definately for the rear ....front bushes might be similar to the skyline .....
  Conrad 2NR said:
Is it possible you can post up the alignment setting for the regular RWD Cefiro?
Unfortunately since the alignment shop had to pay money to get those settings as they're not on the system, I doubt they'll be too chuffed if I ask for regular A31 settings.
Best bet is find a shop with a Hunter alignment machine and ask them to align your car, Hunter should have settings for that too.
As for mine, the rear is adjustable. When it went in both rears matched, they "fixed" the camber on the rear right and then declared that the rear left was too tight for them to undo. This is on a rust-free fresh import, the muppets were also trying to undo it with a 12 sided socket. So I left with one wheel set differently to the other three and now the back end kicks out when I turn left.
The fronts, only option for the Skyline is a set of expensive top mounts. I guess I'll just have to live with the camber for now, just means I can't lower the car :banana:
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 馃槀馃槀 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
    • A pretty cool little feature discovered while restoring my seats.
    • Great write ups / details / photos. I'm sort of on the road to E90 ownership (325i or 330i), haven't hit the fork in the road yet "Yes" | "No", and some of the issues you've faced have me nervous for the age these are getting to nowadays (that wiring, jesus), but I'm guessing the pro's of ownership are still outweighing the con's? Of course, if the bloody tattslotto ROI actually went my way...E90 M3. And I'd have the cash to do all the extra lovely maintenance THOSE require. 馃槃
    • They sure do, great for when you need to chuck a sickie 馃槄   You should definitely give the beast a squirt on the track, great to enjoy the car
