I know there's a thread where all the A31 people have been posting their drifting setups but would anyone happen to know the factory settings that Nissan would have you use, or at least some decent settings for normal road use. Should I just use R32 GTS4 settings?
Oh BTW it's one of the 4WD A31s if that makes a difference :)
https://www.sau.com.au/forums/topic/263861-a31-alignment-settings/
  • 3 weeks later...
Turned out that the company that makes the alignment machine actually have settings for the Cefiro, and they're slightly different from the Skyline.
This scan should show the valid ranges, and also what a crap job the garage did at aligning my car. It handles worse than when I took it in.
Settings may be different if you have an RWD Cefiro. In fact they almost certainly are due to the different suspension design.
Any idea how to fix the front caster and rear toe? Also any cheap way to adjust the front camber as the current level of camber is preventing me from lowering the car :blink:
Edited by Lum
Any idea how to fix the front caster and rear toe? Also any cheap way to adjust the front camber as the current level of camber is preventing me from lowering the car :wub:
There should be some camber bushes available through whiteline ........definately for the rear ....front bushes might be similar to the skyline .....
Is it possible you can post up the alignment setting for the regular RWD Cefiro?
Unfortunately since the alignment shop had to pay money to get those settings as they're not on the system, I doubt they'll be too chuffed if I ask for regular A31 settings.
Best bet is find a shop with a Hunter alignment machine and ask them to align your car, Hunter should have settings for that too.
As for mine, the rear is adjustable. When it went in both rears matched, they "fixed" the camber on the rear right and then declared that the rear left was too tight for them to undo. This is on a rust-free fresh import, the muppets were also trying to undo it with a 12 sided socket. So I left with one wheel set differently to the other three and now the back end kicks out when I turn left.
The fronts, only option for the Skyline is a set of expensive top mounts. I guess I'll just have to live with the camber for now, just means I can't lower the car :banana:
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
