Is this the R33 AFM? (Circled red)
http://i300.photobucket.com/albums/nn37/no...ous_azn/AFM.jpg
If so, how do I open it and clean it? I have CRC MAF.
That is the Airflow meter, not sure what you mean a CRC AFM, but this one looks standard.
In my opinion you can not open the AFM box itself, so do not try... There are some people that can repair if there is a problem but it is filled with hard resin and needs to be looked at by a professional.
I believe it can be re-built but not by you if you don't know how.
They either work or they don't, sometimes they will cause a rough idle and hesitation but they will normally either stop the car or not.
As for cleaning the AFM, only do this when the engine is cold, (at least an hour after turning off) with the Ignition Key off.
Pull the airbox cover off like you have.
Remove the following;
2 bolts holding the lower half of box at front of car
1 bolt on the aft outside
1 on the aft inside.
Hose Clamp that holds Hose to the AFM
Squeeze Tab on Electrical Plug, Push in and then pull terminal up to disconnect AFM from Car Loom.
Then lift the box gently off it's mounts and remove it from Car.
Turn box over and spray Electrical Contact Cleaner down the AFM (probe hanging in the inlet tube) and into the gauze that opens into the Airbox. Use the spray in the reverse direction of Airflow and do not touch the Probe, just use the spray and make sure you get a non residue drying type of cleaner.
Spray both sides of Electrical connection, the 3 pins need to look really clean.
Let it dry for a minute, then re-assemble in reverse... making sure you hear a click on the Electrical re-connection.
Should run a bit smoother now, especially if you have an oiled Air Filter element installed in Airbox.
https://www.sau.com.au/forums/topic/263869-r33-afm/#findComment-4515487
yep thats the air flow meter alright........................
have a look.......
not being able to see your car........
i feel that there is more to it than just an air flow meter......
alot of people having the same symptoms as yours, end up cleaning with AFM withought any improvement....
but it doesnt hurt to try
let us know how you go
https://www.sau.com.au/forums/topic/263869-r33-afm/#findComment-4516640
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
