Will consider trades for S2 R33 GTS-t, R34 GTT or Stagea.
1996 R33 GTR V-spec, Midnight purple. 96,000 km's on engine.
ENGINE
Standard RB26 Engine
Trust Sump & Baffle
INDUCTION
Garret 2560-10 Turbo's
Sard 720cc Injectors
Apexi Pod Filters
FUEL SYSTEM
Custom Surge Tank
Bosch 044 Fuel Pump
Sard Fuel Regulator
Braided Fuel Lines
ELECTRONICS
APEXi Power FC with hand controller
Blitz DSBC Boost Controller
EXHAUST
Tomei 3" Dump Pipes
Custom 3" with twin mufflers
DRIVELINE
OS GIKEN triple plate clutch
NTERIOR
Nismo 320km/h speedo
Momo steering wheel
Price: $25,900
Pics of car with hi-res pics can be seen on the link below (better quality pics to appreciate the condition of the car). Comes with standard GTR wheels.
http://www.allblitz.com.au/cars/gtr800hp.htm
Hey i am very interested in ur gtr. i have a s2 gtst that i need to get rid of in order to buy ur car. would u be interested in a trade. its a 96 sliver r33 gtst with 66,000kms in mint condition. plus the rest in cash? what do u think?
