hi guys,
i spoke to a well respected engine builder today who recommended the use of a vl turbo oil pump on my rb26/30 build & the oil pump collar is not required...has anyone heard this before? its news to me...
regards,
hi guys,
regards,
yes ive heard that plenty of times.
the vl or rb30 pumps run a steel inner gear/sleeve then that mates to the conventional oil pump.. not the sinterd type of later.. but i dont think the flow is up there.
ps, they are a spur gear type aswell and do cavitate at high revs.
external is better. id look at the calias forum to back it up.. ;)
I was under the impression the 30 pump did not fit onto cranks that already have the collar or the extended factory snout.
Which pretty much limits you to R32 GTR cranks and 20 and 25's.
The cavitation is a critical issue as mentioned above.
a very learnered man told me a few weeks ago on his trip from QLD that RB30's don't smash oil pump's because the crank's are really heavy.
unless you live on the limiter that is.
So i don't think it matter what pump you have
Yes he would have to be one fella who i would trust with anything he told me.
if anyone 'actually' knows whats going on, its him.
Edited by DiRTgarage
NOPE.
On the RB30 oil pump GEAR it only has 8mm surface area on the crank collar itself, where RB20-25-26 have almost 25mm surface face on the crank.
You do the maths at 7000RPM.
NOPE.
But if the crank has a narrow oil pump drive...it would only still have 8mm of contact. It wouldn't matter which pump you used.
Id prefer to use a pump which mated to the entire face of the drive...not just a small portion of it...this in my opinion is part of the whole RB oil pump saga and why Nissan extended the drives on later crankshafts.
Can someone correct me if I'm wrong in my above post? I am almost 100% certain that RB30 pumps don't fit onto most of the cranks out there? This is due to the different gear design and different flats on the drive.
Never tried to put one on a standard 20/25 crank though.
Are these slightly out of focus pics. any help?
now that vl pump is that a turbo pump or a n/a pump as they have different part numbers. also when i rebuilt my rb30 i try'd to source a new pump from holden but
pretty much everything engine related is no longer avaliable so i took my vl turbo oil pump part numbers to nissan and got a new pump but i was told it was a common pump
ass it was a r32 gtr pump. i don't know if they we're originally or if they we're just revised to that but thats my 2cents
NOPE.
Sad story, It's even worse than that.
The contact area is half the gear's thickness, about 4mm contact with the crank. (This is from a N/A Rb30)
Always believed they ran the same pump as the turbo, but it's been ages, those photos are many years old.
I took that second slightly out of focus photo comparing the 4 gear sets, that is a regular non turbo VL gear set. They wont fit a 33 or later crank or one fitted with a normal collar as the longer drive wont fit through the pump housing. I have made custom collars to suit them, they just need the drive area narrowed. Mostly I make those collars for the guys with the RD28 diesel engines, they are really hard on pump drives and the pump housing is different so you can't run a 25/26 pump on them. If you want to run a VL pump, unless the drive is perfect I'd still fit a collar to it. I'm making a collar for an RD28 this afternoon, I'll take some photos to show the difference.
I've never seen one of the vl pumps with broken gears but they are lower volume than a g-rotor pump. The turbo pump is slightly bigger than the NA one. They also run very low pressure at idle, from memory around 100kpa though it rises very quickly once the revs rise.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
