As some of you will know I have been eagerly awaiting my new Nismo Fuel pump to arrive for my R33 GTR. It did just that yesterday, but unfortunately due to a mix up it is an R32 GTR pump which is useless for me. I am having the correct one freighted over asap, but since this one is still in Perth there is a very small window of opportunity for someone else to grab this pump.
Details are: Nismo 280lt/hr (4.6lt/min) rated to over 600hp brand new still in the bag not opened. Is a straight drop in, comes complete with new filter bag and everything.. Nissan Australia will warrant this Item for 12 months. I know this because I checked with them.
It cost me $547 delivered and that is what you will need to pay. I am not out of pocket over this as I will be sending the Pump back to the supplier so if you want this let me know today if possible.
I can be contacted on 0407 779 221 or email on [email protected].
This is a Perth only offer...
Cheers
Brett
https://www.sau.com.au/forums/topic/26390-my-bad-luck-could-be-your-good-luck/
Kym, The big Bosch pumps are not a straight drop in to a 33, you have to run a surge tank and a lift pump. Add that all together and you are up around the price for the Nismo pump. Also to buy one here is around the $880 mark so all in all a good price. I also then have my stock pump to sell which brings my outlay down even further....
Paul, Fingers crossed man!!!! Worst case we can try and tune with the stockie and hope it doesn't ping...
I've been told by numerous (at least half a dozen) different tuners that a 044 pump will not straight fit into an R33 GTR. I even rang Tillbrooks over east as there was a HPI article saying they had done it. I spoke to Mark Tillbrook himself and he told me the article was incorrect and there was no way it would fit.
I understand that the GTSt's are the same, but don't quote me on that..
Besides, $547 for the Nismo less say $200 for my stock pump means I have a straight drop in 600hp pump without using surge tanks etc for around $350...
No issues with cops and surge tanks either...
I dont think any of the bosch pumps are a straight fit, you have to modify the brackets that it sits on to get it to "bolt" into place. I have a bosch 910 in mine, went into the tank and there was a thread for a "DIY" bosch 040 or 044 into the tank of a gtst, again you have to modify the brackets but I believe it did fit in.
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
