Hey everyone, I just got the call today that my GTR is ready with new garrett 2860r-5's, On the phone he said i gained a bit of midrange power than the previous setup i used to have trust t517z's. Its making the same peak power as before but im just a bit spectical for some reason after that that he has used -7's i figured that i would have no gain in midrange and a better topend. I havent asked him what the top end is like he know's that i like a bigger kick rather than response so i figure if it is making more midrange that the top end will drop off. I know that with -5's the Topend should Definitely should be there and start to pull from higher in the rev range and not lower and die off. Any ideas? i havent asked him when its making full boost yet and if it does pull hard to redline. Thanks for some advice.
Depends on what spec the 517's were in.
You've really provided no info dude... what power it has made, dyno sheet with boost plot etc etc.
Only way to check it the turbo ID tag, good luck getting a look without taking half the car apart
Haha yeh thats what im afraid of mate. Thats why im hoping he doesnt screw me knowing that you know. I have aftermarket induction piping so i can get all that off Pretty easy i didnt think the garrett's came with anything on the ID?. The t517z's where the 8cm Version brand new.
I know that the -5's arnt that good for a standard rb26 my internal's are standard i decided on the -5's because im planning on doing a rebuild later on and using them for what there capable of alot more boost. Right now i think its running 19psi so they should have alot more in them yeh? i will ask the tuner on 19psi they shouldnt run out of puff at 75000rph yeh? im not saying they are i havent seen the dyno sheet yet im picking the car up this afternoon. I guess if it comes on boost early and has a gradual power increase that doesnt hold till redline there not -5's. I have cam's just about ever bolt on mod accept internal's. Just makes me really wonder about gaining in the midrange you know i just dont think it should gain in the midrange if i have big turbos that should have a bit of lag. BTW it made about 400hp on 18psi like the t517z's did at 18psi.?
What - why did you change from T517Zs to GT2860-5s? I was always pretty sure the T517Zs are a slightly larger turbo than the GT2860-5s/GT2530s? Also if you are maxing neither out you're not too likely to see gains, need more info on your setup but I am getting the feeling you just did a side step if not a downgrade in flow potentially and wondering why you didn't get more power.
Mate i changed the turbos because they siezed. ill get the dyno sheet up tonight.
wouldnt it have been easier to get them rebuilt rather than buying 2 new turbos of poorer quality????
i never said they were no good just maybe not as good as the t517
just an opinion.
and dont they have a warranty to die after 4000km i would imagine the supplier would have some sort of warranty...
Also i dont think the -5's are the same as 2530's thats the -7's
*shakes head*
I think you really need to get your turbo part #'s, and specs correct before you go saying you think you dont have what you paid for.
-5's are similar to a HKS 2530
-7's/-9's are similar to HKS GT-SS/R34 N1
There is enough info on the forum stating the above im not sure how its even something that you could get wrong.
Even Garretts website will tell you the HP rating for each.
If the reciept has the part# of -5's on it, then thats what you have. Have you even checked it yet?
Also did you fix the problems that causes the 517's to seize? Because if you didnt, it'll happen with the -5's... turbos done just "seize" for no reason, especially not near new ones.
Yep x2 ^^ Thats exactly what I was going to say on both fronts. The Mitsi/Trust turbos are strong as hell and aren't inclined to just seize - especially both of them!! It would have been cheaper and easier to take them to a turbo expert to look at what caused them to fail and then get that address fixed and the turbos rebuilt.
Depending on the dyno you are using you probably could do with more work to the engine itself as neither turbo combination should be limited to 300kw @ wheels, makes me think the engine itself is the let down.
Edited by Lithium
*shakes head*
Just for reference for those playing at home(GCG has a run down and a link to the Garret flowcharts)
2530- http://www.gcg.com.au/turbo/ViewProduct.aspx?ProductID=15
GT-SS- http://www.gcg.com.au/turbo/ViewProduct.aspx?ProductID=11
R34 N1- http://www.gcg.com.au/turbo/ViewProduct.aspx?ProductID=16
Lists the differences in HP and the turbo itself, and GCG specify the -7 as R34 N1 with the other two as "upgrades" with the -5 having a higher HP rating.
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
