Hey everyone, I just got the call today that my GTR is ready with new garrett 2860r-5's, On the phone he said i gained a bit of midrange power than the previous setup i used to have trust t517z's. Its making the same peak power as before but im just a bit spectical for some reason after that that he has used -7's i figured that i would have no gain in midrange and a better topend. I havent asked him what the top end is like he know's that i like a bigger kick rather than response so i figure if it is making more midrange that the top end will drop off. I know that with -5's the Topend should Definitely should be there and start to pull from higher in the rev range and not lower and die off. Any ideas? i havent asked him when its making full boost yet and if it does pull hard to redline. Thanks for some advice.
Depends on what spec the 517's were in.
You've really provided no info dude... what power it has made, dyno sheet with boost plot etc etc.
Only way to check it the turbo ID tag, good luck getting a look without taking half the car apart
Haha yeh thats what im afraid of mate. Thats why im hoping he doesnt screw me knowing that you know. I have aftermarket induction piping so i can get all that off Pretty easy i didnt think the garrett's came with anything on the ID?. The t517z's where the 8cm Version brand new.
I know that the -5's arnt that good for a standard rb26 my internal's are standard i decided on the -5's because im planning on doing a rebuild later on and using them for what there capable of alot more boost. Right now i think its running 19psi so they should have alot more in them yeh? i will ask the tuner on 19psi they shouldnt run out of puff at 75000rph yeh? im not saying they are i havent seen the dyno sheet yet im picking the car up this afternoon. I guess if it comes on boost early and has a gradual power increase that doesnt hold till redline there not -5's. I have cam's just about ever bolt on mod accept internal's. Just makes me really wonder about gaining in the midrange you know i just dont think it should gain in the midrange if i have big turbos that should have a bit of lag. BTW it made about 400hp on 18psi like the t517z's did at 18psi.?
What - why did you change from T517Zs to GT2860-5s? I was always pretty sure the T517Zs are a slightly larger turbo than the GT2860-5s/GT2530s? Also if you are maxing neither out you're not too likely to see gains, need more info on your setup but I am getting the feeling you just did a side step if not a downgrade in flow potentially and wondering why you didn't get more power.
Mate i changed the turbos because they siezed. ill get the dyno sheet up tonight.
wouldnt it have been easier to get them rebuilt rather than buying 2 new turbos of poorer quality????
i never said they were no good just maybe not as good as the t517
just an opinion.
and dont they have a warranty to die after 4000km i would imagine the supplier would have some sort of warranty...
Also i dont think the -5's are the same as 2530's thats the -7's
*shakes head*
I think you really need to get your turbo part #'s, and specs correct before you go saying you think you dont have what you paid for.
-5's are similar to a HKS 2530
-7's/-9's are similar to HKS GT-SS/R34 N1
There is enough info on the forum stating the above im not sure how its even something that you could get wrong.
Even Garretts website will tell you the HP rating for each.
If the reciept has the part# of -5's on it, then thats what you have. Have you even checked it yet?
Also did you fix the problems that causes the 517's to seize? Because if you didnt, it'll happen with the -5's... turbos done just "seize" for no reason, especially not near new ones.
Yep x2 ^^ Thats exactly what I was going to say on both fronts. The Mitsi/Trust turbos are strong as hell and aren't inclined to just seize - especially both of them!! It would have been cheaper and easier to take them to a turbo expert to look at what caused them to fail and then get that address fixed and the turbos rebuilt.
Depending on the dyno you are using you probably could do with more work to the engine itself as neither turbo combination should be limited to 300kw @ wheels, makes me think the engine itself is the let down.
Edited by Lithium
*shakes head*
Just for reference for those playing at home(GCG has a run down and a link to the Garret flowcharts)
2530- http://www.gcg.com.au/turbo/ViewProduct.aspx?ProductID=15
GT-SS- http://www.gcg.com.au/turbo/ViewProduct.aspx?ProductID=11
R34 N1- http://www.gcg.com.au/turbo/ViewProduct.aspx?ProductID=16
Lists the differences in HP and the turbo itself, and GCG specify the -7 as R34 N1 with the other two as "upgrades" with the -5 having a higher HP rating.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
