  • Replies 98
Posted Images
alright so i took these at the end of march but anyway...in case anyone else was there and wants some pics :(
whoop ass wednesday
edit: oh lots of fords because I was there for a ford thing.
Edited by mickey
Something went wrong tonight when i was shooting the moon (most of my shots didn't come out well at all as i was expecting)
Anyways this was the best shot i could do.. should try again while its still full moon.. but i cbf.. lol
AAAARGHHH !!!! went to do a shoot on my car and before I could get some good shots I found that every shot I took had green marks in the pic, anyone know what it is? It's one of my fav lens :P
Looks like some sort of green light nothing to do with the camera/lens in my opinion. I mean look down towards the right of the car theres a line of green light flashing onto it. im guessing the massive green spot in the middle of the image is coming from whatevers doing that green line aswell..
Wow some nice images in here :)
Cali great work with the bonnet pic..
nice panning shots there bnr...
Takz- Nice attempt with the digi cam!! I really wanna head back into the city one day to take some images with my new lens.. one day..
Zennon - nice concept i like it.. esp that first one.. But i wish the shutter speed was a tad slower.
anyways nice work slim as always!!
Not really photography, but here is my new marine setup im working one :blink:
- My 4*2*2 tank im going to be using.. much bigger than my current 70L tank :) heheh
- atm i got my corals etc in these huge drums.. waiting to get the tank drilled etc. .and im gonna make a new stand for it..
Anyways did you know Prank (owner of this site) is fully into marine setups!! who would have thought..
I spotted him on marine forums :)
thanks for the comment!
i can't decide whether to invest in a dslr cause i don't want to buy one then not end up using it! Well i have to try some night shots of my car and see how it turns out
that looks like a big project you got there!!! better take some nice photos once you get it running!
You will apprieacte photography more with the dslr.. But im biased :)
Heres a few pics taken with a dslr with stock kit lens.. So nothing special..
So same pictures of what you took - well similar:
http://i7.photobucket.com/albums/y276/sidd...MG_1295_PPc.jpg
http://i7.photobucket.com/albums/y276/sidd...MG_1278_PPc.jpg
http://i7.photobucket.com/albums/y276/sidd...MG_1309_PPc.jpg
http://i7.photobucket.com/albums/y276/siddr20/IMG_1301.jpg
http://i7.photobucket.com/albums/y276/siddr20/IMG_1324.jpg
http://i7.photobucket.com/albums/y276/sidd..._1293__PPns.jpg
hehe dont worry, i will be taking lots of photos when i get it up and running ;)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
