  • Replies 98
Posted Images
Nice zennon :ph34r: Love it!!
so what did you do for that 1hr :)
well there was 3 of us there - so two of us went for a drive to shops and got some maccas - while we left 3rd guy to look after gear lol
new version of froggy:
didn't realise how badly i stuffed up the background
(had contrast and brightness maxed for counter strike so i can see the bastards in the dark lol)
Love the frog shot zennon!! Looks cute too hahah
DCIEVE - Nice panning attempt dude :) any more?
Cheers, that one prob turned out the best, got hundreds more :/ Will throw up a few more of the ok ones later tonight. Was tough getting decent shots with the kit lens at full zoom on a dark/overcast day.
Edited by DCIEVE
Love the first two shots Zennon!! Keep it up :laugh:
Thinking of selling my 70-200L lens.. anyone keen? Practically new and only used 4 or 5 times at most..
1k firm..
Anyone?
Reason for sale: Need to pay off some things so need the cash.
1k firm..
Anyone?
tempted. Should probably be buying an external flash first though.
hmm any chance you could get it too me in st leonards..? :laugh: i work nights too.. so any time till 11pm in st leonards im here...
i've got no time outside of work atm... away this weekend for track days and next week im heading to Hawaii so would rather have it before I go.....
argh I dont know if I can justify the cash
Not a problem i can arrange that!!
Will be in the city on thursday so perhaps we can work something out?
I got a client shoot then somewhere in the city.. so yea let me know dude!!
Sidd.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
