When i bought my R33 the Nissan Boot Lock Cover had either broken off or been stolen. I didn't like the look of it not being there so i hunted around and found replacement ones, but the original's are quite expensive and where out of my price range, Just Jap Auto Imports sell them here as an OEM item. As i didn't want to spend that much for an original, i had a look for a secondhand one, i managed to find someone on here, who was wrecking there R33. I sent him a PM, he told me he was selling it on ebay, so i bought it off ebay.
Now i have a replacement lock, but no key. I was told by some people i could take this lock to a locksmith and have a keymade up to it, and some others said to have the barrels swapped. I didnt exactly like the ideas of having extras keys just so i can open the boot, so i decided to go along the path of having the barrels swapped. I took my original one out of the car to take to a locksmith and have the barrel swapped into the replacement.
Of course being me i had to put the key in and see how it worked, i then thought it look rather easy to do myself, and decided to give it a crack. I did go looking on the net a bit for some help doing this, but nothing popped up.
So here is a guide on how to swap the R33 Boot Lock Barrels.
Boot Beforehand
Inside Boot Panel, you need to remove the blackclip for the lock to come out, a bit of twisting and pulling will get it.
Once the black clip is removed, it should pop out easily.
Now that it is out, this is what the back looks like.
See that clip at the very top, remove that with a flathead screwdriver, carefully so you dont hurt yourself.
Now remove the arm, this just pulls straight off once that clip is removed.
You can also remove the black seal at anytime you like, i did mine at this step.
Now, see that spring. That needs to come off, comes off rather easy with a small screwdriver.
Ok, now you need to release the actual barrel now. See those 4 holes, if you look in you can see plastic taps. What you need to do is puch them towards the centre and down so it pops out the black circle on the front. (Sorry about the bad images from now on, i put my camera on charge while i went out, and forgot to put the macro setting back on, but you can still get the idea)
Now, push the barrel out from the back, fowards. If you are worried about it falling apart, it might be a good idea to put the key in. It may or may not make a difference, i am not sure.
Now this is what you should be left with.
Now do the exact same to the other one. Then swap the barrels from yours into the new one, and do everything in reverse. The black circle will only go in one way as it is tapered, and the spring will also only go in one way. As you are reassembling, it maybe a nice idea to add some grease onto the barrel.
Now for the finished product.
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/
Good tutorial Aberax :(
A couple of tips for ya,
Put the key in if your scared the wafers will fall out. Putting the key into the barrel will hold them in.
Even better idea is to swap the wafers out into the new barrel as this will give you a fresh keyway. Just be careful not to lose the wafer springs.
Don't grease the barrel, wet lubricants attract dust and it stays in there. Use a dry lubricant like graphite.
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-4515732
oh nice...just what i needed. boot a spoiler off a guy on sau but he didn't wanna take the spoiler off his boot so he is giving me the boot with it lol.
thinking just to use the boot lid that my spoiler is coming with so i'll just swap the locks over. thanks mate!
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-4516463
  KeyMaker said:
Good tutorial Aberax :cool:
Thanks for the extra tips mate. I suggested grease as a lubricant as while working on the barrel it seemed to be covered in either grease or machine oil, not really too sure. But graphite also works :P .
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-4518036
  • 3 weeks later...
how on earth did u get to take the rear badge out im trying to do the same thing but to no luck...i removed the boot liner, unscrewed the latch thingy and i could not get to it from underneath as it is covered by metal (if u get what i mean) not sure how u got to the second pic...sorry man such a noob i swear..i couldnt work it out
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-4557473
ok, a bit of a quicker run down.
1. Open boot
2. take boot lid lining off
3. look/feel inside the boot where the lock is and you should see/feel the black metal tab
4. wriggle the tab up and down while pulling on it, it will eventually pull off
5. lock should now come off of/out of boot lid
For the second pic, i put my camera in one of the holes and took the photo. Take for instance the left of the second pic, you see the white surface, that surface is the rear of the boot, as you can see the lock barrel there, so on the other side of that surface would be the emblem cover for the lock. Once you take the boot lid lining off you should get a better idea. My car didn't come with any boot lid liner, so that's why i didn't write that step in originally.
Hope that helps a bit.
Edited by Aberax
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-4559434
I just done this..
If anyone has the badges still on there, just lift it up abit and move it outwards, use a bit of force, and now you will be able to get the black rubber and the key barrel out.. hope this helps anyone that had the same as me..
thanx 4 the diy again..
Edited by seriesII
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-4583884
i took mine off and just smacked fibre glass over the hole sanded it back than voila shaved boot hehe it thought it pointless to have a key there when the lever is just as easy to use
also dont have to worry about people trying to break into your boot, just an idea
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-4614972
  • 3 months later...
  • 8 years later...
  • 4 months later...
Fantastic diy and super easy! Once i removed the barrel i left the key inside so the pins wouldnt fall out and i could see which pins were sitting higher. With the key still inserted i grinded off about 0.5mm on 2 of the pins. [emoji5]
https://www.sau.com.au/forums/topic/263946-r33-boot-lock/#findComment-7869616
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
