Hennessey 700hp Package @ $26k Aud For The Bits
http://www.themotorreport.com.au/25518/hen...age/#more-25518
* 0-60 mph: 2.8 sec. (stock = 3.4)
* 0-100 mph: 6.7 sec. (stock = 8.3)
* 0-150 mph: 14.5 sec. (stock = 19.5 sec.)
* 0-186 mph: 24.7 sec. (stock = 53.3 sec.)
* 1/4 mile: 10.8 sec. @ 133 mph (stock = 11.8 sec. @ 118 mph)
Check out the Utube video of the car on Hennessey's website. The acceleration of the car is bloody brutal. Must put a lot of stress on the tranny, surely you'd have to upgrade the internals for long term reliability.
http://www.hennesseyperformance.com/ItemDe...ActionReq=Where
Edited by GT-R OZ
Trans upgrade is included. You can get a gearset from PPG.
Brakes - only required if you will do any serious track work. Any production car has crap brakes for serious track work and needs at minimum upgraded pads and disks.
1/4 mile time is still a bit slow considering boosted stock turbos and a good launch get the car to run low 11s, high 10s.
From link:
Power:
715 hp @ 6,500 rpm
662 lb-ft Torque @ 4,100 rpm
Performance:
0-186 mph: 24.7 sec. (stock = 53.3 sec.) 1/4 mile: 10.8 sec. @ 133 mph (stock = 11.8 sec. @ 118 mph)
Includes:
SUMO ™ Stainless Steel 88 mm Catback Exhaust System
SUMO ™ Stainless Steel Midpipe Exhaust
SUMO ™ Engine Management Computer Programmer (17 psi boost)
SUMO ™ Intercooler Piping Upgrade
SUMO ™ Inlet Piping Upgrade with Stainless Steel Blow-off Valves
SUMO ™ Sport Turbo Upgrade – Modified Factory Turbos with 47 mm Compressor Wheels (stock compressor wheels = 42 mm)
SUMO ™ Modified Factory Wastegate Actuators
SUMO ™ 100 mm High-Flow Cold Air Induction
Modified Factory Mass Air Sensors
High-Flow Fuel Injectors with Custom Calibration
Transission Cooler Upgrade
Transission Clutch Pack Upgrade
Professional Installation
All Necessary Gaskets & Fluids
Chassis Dyno Tuning & Engine Management Calibration
Powered by Hennessey Custom Floor Mats
Limited Edition GTR700 Plaque in Interior & Engine Compartment
Factory Engine Cover in Red with black GTR600 Badges
Hennessey & GTR700 Exterior Badges
The GTR700 kit is also available via mail order and it can also be exported internationally.
Optional Upgrades:
SUMO ™ Electronic Exhaust Cutout (75 mm)
KW Variant 3 Adjustable Coilover Suspension Upgrade
HRE C91 Light Weight Alloy Wheel Upgrade (set of 4)
SUMO ™ Brand Hennessey Performance Engineering (HPE) is proud to introduce its own line of high-performance parts & accessories for the R35 Nissan GTR. As the name implies, our SUMO ™ performance brand is big and powerful. Each individual component included in the GTR700 upgrade is available individually on a mail-order basis. GTR owners can order SUMO ™ performance parts from HPE by calling or by visiting the company’s new web store at HennesseyPerformanceStore.com
  • 8 months later...
  • 1 month later...
  • 1 month later...
Having read several write ups on Hennessey on other forums, I'd suggest you steer clear of them.
If you send money, you may not get your parts, if you send your car to them, you may not get it back and if you buy a car from them, expect to find some nasty surprises!
Just buy the equivalent HKS parts, apparently Hennessey just copied them anyway.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
