Hennessey 700hp Package @ $26k Aud For The Bits
http://www.themotorreport.com.au/25518/hen...age/#more-25518
* 0-60 mph: 2.8 sec. (stock = 3.4)
* 0-100 mph: 6.7 sec. (stock = 8.3)
* 0-150 mph: 14.5 sec. (stock = 19.5 sec.)
* 0-186 mph: 24.7 sec. (stock = 53.3 sec.)
* 1/4 mile: 10.8 sec. @ 133 mph (stock = 11.8 sec. @ 118 mph)
Check out the Utube video of the car on Hennessey's website. The acceleration of the car is bloody brutal. Must put a lot of stress on the tranny, surely you'd have to upgrade the internals for long term reliability.
http://www.hennesseyperformance.com/ItemDe...ActionReq=Where
Edited by GT-R OZ
Trans upgrade is included. You can get a gearset from PPG.
Brakes - only required if you will do any serious track work. Any production car has crap brakes for serious track work and needs at minimum upgraded pads and disks.
1/4 mile time is still a bit slow considering boosted stock turbos and a good launch get the car to run low 11s, high 10s.
From link:
Power:
715 hp @ 6,500 rpm
662 lb-ft Torque @ 4,100 rpm
Performance:
0-186 mph: 24.7 sec. (stock = 53.3 sec.) 1/4 mile: 10.8 sec. @ 133 mph (stock = 11.8 sec. @ 118 mph)
Includes:
SUMO ™ Stainless Steel 88 mm Catback Exhaust System
SUMO ™ Stainless Steel Midpipe Exhaust
SUMO ™ Engine Management Computer Programmer (17 psi boost)
SUMO ™ Intercooler Piping Upgrade
SUMO ™ Inlet Piping Upgrade with Stainless Steel Blow-off Valves
SUMO ™ Sport Turbo Upgrade – Modified Factory Turbos with 47 mm Compressor Wheels (stock compressor wheels = 42 mm)
SUMO ™ Modified Factory Wastegate Actuators
SUMO ™ 100 mm High-Flow Cold Air Induction
Modified Factory Mass Air Sensors
High-Flow Fuel Injectors with Custom Calibration
Transission Cooler Upgrade
Transission Clutch Pack Upgrade
Professional Installation
All Necessary Gaskets & Fluids
Chassis Dyno Tuning & Engine Management Calibration
Powered by Hennessey Custom Floor Mats
Limited Edition GTR700 Plaque in Interior & Engine Compartment
Factory Engine Cover in Red with black GTR600 Badges
Hennessey & GTR700 Exterior Badges
The GTR700 kit is also available via mail order and it can also be exported internationally.
Optional Upgrades:
SUMO ™ Electronic Exhaust Cutout (75 mm)
KW Variant 3 Adjustable Coilover Suspension Upgrade
HRE C91 Light Weight Alloy Wheel Upgrade (set of 4)
SUMO ™ Brand Hennessey Performance Engineering (HPE) is proud to introduce its own line of high-performance parts & accessories for the R35 Nissan GTR. As the name implies, our SUMO ™ performance brand is big and powerful. Each individual component included in the GTR700 upgrade is available individually on a mail-order basis. GTR owners can order SUMO ™ performance parts from HPE by calling or by visiting the company’s new web store at HennesseyPerformanceStore.com
  • 8 months later...
  • 1 month later...
  • 1 month later...
Having read several write ups on Hennessey on other forums, I'd suggest you steer clear of them.
If you send money, you may not get your parts, if you send your car to them, you may not get it back and if you buy a car from them, expect to find some nasty surprises!
Just buy the equivalent HKS parts, apparently Hennessey just copied them anyway.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
