  • Replies 615
Posted Images
All going to plan, these should be on by the end of the week, and I should have some nice brakes to post up too :happy:
What upper arms are you going to use on the front? I have the Ikeya LCA kit but still undecided on what to use for the uppers.
Nice work on the build and thanks for constant updates. :(
haha, seems fats is doing the rain dance...i might have to put my wipers on.
how are you looking?
:rofl::):blink:
Errrrmmmm... I don't actually have wipers on the car, and I have NO idea where they are :huh:
Will have a better idea on whether or not I'll make it by about Thursday 8pm :bunny:
Nice work on the build and thanks for constant updates. :bunny:
Thanks mate :rofl:
I have Cusco ones (-10mm), as I like the idea of fixed length parts... I just don't trust those "silk road" or "midori" style sliding ones.
...but I'll see how I go... I might change to UAS pivoting upper arms sometime in the future...
Mmmm... Nice power curve!
All on a stock engine!!! :P
Nice curve Andrew.
Dont feel you need to blank out the number though, there's no shame in having a GTR in the 200's hahaha
Still -7's?
So this means we'll be seeing you on Friday then...?
Here's GT-RS's as a comparison for you
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
