  • Replies 615
Posted Images
I'm not a big fan of carbon clutches in a daily driver, their operating temperature window is too narrow. They slip like crazy until they get up to temperature. Even in a race car I have had one inexperienced guy kill one, just on and off the trailer and driving around the pits.
Cheers
Gary
<sigh>
Thanks for the heads up guys...
I've been through seven different twin plate clutches (and one triple) in my travels, some good, some bad, some excellent....
I thought I'd try something new, but after hearing the above reports, I'll stick with the tried and true OS Giken TS2CD. It'll be my THIRD one :)
At least it'll be a known quantity, but I miss out on trying new technology ;)
Thanks Baboo...
I'll stick with the known quantity OS Giken one for now, and consider trying a carbon one later down the track when I'm chasing extreme weight saving :)
Mark Berry, Russell Neuman, Mark Jacobsen and Paul Diemar use NPC twin plates.
Buy a real clutch Merli...not one that comes in a shiny box with fancy stickers.
I'll second the NPC. I've had it in the car for over 2 years and it's never slipped at the circuit or the drags and it's really easy to drive on even with the push/pull converter.
<sigh>
At least it'll be a known quantity, but I miss out on trying new technology :cool:
I have an OS Giken Twin Plate in my own R32GTST, I just service the plates regularly, just like brake pads they wear out. In the race cars we only use AP Clutches, 7" in the turbos and V8's and 4.5" in the 4 cylinders and rotaries. They are not cheap, but nothing good ever is. It's the combo road and track cars that I have the most problem with clutches, the compromises seem unavoidable. Either they are snappy and heavy for daily driving or can't handle track work or they wear out real fast. Depite many years of looking I haven't as yet found one that doesn't have at least one compromise.
Cheers
Gary
I've heard nothing but good things about NPC clutches, may try one down the track.
I use an OS twin plate which I just had rebuilt after doing this to it...
Lasted a long time though, and copped some fair abuse. I'm a big fan of it.
Twin plate Direct racing clutch, manufactured by "DIRECT CLUTCHES" here in Brisbane....great clutch and easy to use.
Had one in my STI for years of trouble free driving...recently tried the Excedy....worst clutch by far and after using it for the past 4 weeks, I will be getting the Direct clutch rebuilt.
I originally purchase the pictured clutch for the GTR....but after a test drive in AtomicBomberman (Chris) GTR, decided to give the carbon ATS clutch a go
ive used extreme single plates, os giken quad plate, direct clutch twin (older version) and a npc twin and the npc is the easiest to drive, handles 600rwhp drag launches time and time again, plus hard shifts with a dogbox and it is awesome to drive around town, the engagement is sooo smooth. The os qaud was an absolute pain to take off from lights etc i didnt like it one bit.
NPC twin is $2000 from memory, these are cheap as to rebuild as well unlike the os giken ones, definately top notch. My twin plate is bigger than the quad plate, its definately a serious piece of workmanship.
$2400 retail...a little cheaper for trade
ARP flywheel bolts $110 retail...again a little cheaper for trade.
Edited by DiRTgarage
thats a sprung centre one, mines a solid centre and still a treat to drive, they are absolutely huge for a twin plate too
ive never had to drop the engine xmember to put box in either, just tip the motor right back and ya fine.
Edited by unique1
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
