Interesting development!
Carlo, I have decided to go for an ATS carbon twin-plate, so unfortunately your Exedy clutch will not get a run this time, but I think it would be great for all of us if we could address the issues raised by Risking and Dazmo... In addition to the above two comments, I also heard of instances of the clutch shearing the flywheel bolts (below pic)...
As you can imagine, cars on this website (and in this section specifically) make pretty high power and torque numbers, so it would be great if I could put Exedy back on our lists for the next clutch that we all will inevitably have to buy...
I was definitely drawn (and also at the same time.... apprehensive) about the flywheel design. It looks extremely light... Possibly TOO light? Are you able to give us some weight specs of the clutch (total), clutch discs and flywheel?
Cheers,
Andrew.
  • Replies 615
Posted Images
Nothing doing :D
Car is sitting very stationary in a corner of John's workshop until my clutch comes... I've been told "about a week".
Sorry Daz, but I couldn't pull out of the purchase. Once they have your money, there ain't no getting it back :(
we put a exidy twin in the targa car for the v8 supercar support race, i think it was a carbon one by the price (dad just got it fitted and didn't tell me much about it). But dad kept over heating it on the start line, seems it dosn't like being revd for very long on the line. Which left him with clutch slip for 1/2 a lap (he backed off till it gripped again) Never had that problem with the sports ceramic that we run in targa.
After chopping and changing about eleventy billion times, I'm currently waiting on a Nismo Coppermix Twin Plate (Competition Spec)
Nothing wrong with that Andrew, I have a super coppermix twin plate and must say its the best clutch I've had in regards too how light it is on the leg and has quite a bit of give on taking off. It's not a ON/Off sort of clutch that jerks or stalls if not given heaps of revs..
Other clutches I have used are Nismo G-MAX twin plate, Exedy twin plate and OS twin plate.
Oh, and my car did see the track quite a bit, handling 350rwkws no problem....
Exactly. Hence why its standard issue in the ZTUNE...
Hi Jack, and good choice Andrew. You realise your car is late model R32 and has pull type clutch, so you will need to convert everything over to push type? I guess who you bought this from advise on this? That silver R32 GTR here the silver one has one of these clutches, and nice to drive yet strong.
FYI car is on hoist looking at us, waiting, with The SLot Car sleeping underneath atm.
if he ordered the right nismo coppermix clutch (ie a late 32/33 pull one) then he wont need the converter stuff. they make a compatible clutch so you don't have to convert. :down:
ouch!
ahh well even if its the wrong one its easy enough to convert the box to push, and gives a better selection of aftermarket clutches too.
those os/giken style pull to push kits on the other hand sound like a silly idea
Hey all...
Yep, I know that I have a PULL gearbox.... I made sure that I ordered a PULL version, so it should bolt straight on :P
Clutch should be here soon, so hopefully the white whipper snipper will be moving under its own power again soon!
Hey Risking
Would be very interested to hear about what broke , in the Twin Plate Exedy Carbon-R Kit , As i mentioned to merli any info on this style of kit would be fantastic , Reason for asking i'm the Qld Sale's Rep for Exedy Australia , All an any feed back on the kit would be fantastic !
Cheers
Carlo
Qld Sale's
Exedy Australia Pty Ltd
Eagle Farm Qld .
Not to go off on a tangent too much from this build thread, but seeing you posted I shall post the crap your company sold to me, then didn’t want to know about it nor want to inspect it for a design fault.
This clutch, was installed by a clutch specialist, this clutch lasted not even 72hrs. I wanted a clutch to use in my car as my OS twin plate was getting rebuilt. The phone monkey at the time was adamant this would be up to the task…
To be honest as this was a couple of years ago, I’m not even phased if you reply.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
