They are on rowdy gtr's old car on here or his current one..? i think he said his were 18x10 when i was picking his brain about them.. did you get all adjustable arms? should be able to fix the offset a little with them.
Looking good otherwise Andrew :P i think you've sparked some inspiration in me finally.
if the weather is fine this weekend i'm getting stuck in.
  • Replies 615
Posted Images
Suspension and brakes are all stock at the moment... I'm leaving the two most important parts of the car until last.
.... and yes, I'm counting on the 3-4 degrees neg camber to fix the offset issue at the front... I hope that guard rolling will be sufficient to take care of the rear.
I'm not worried anyway... If I need to get the guards panel beaten to make them fit, so be it. dunno.gif:P
Check out the g-sensor that I bought... Don't ask how much this was. My sphincter is still puckered after handing over my credit card :)
If you dont mind me asking, how much d!ck does nissan stick in your butt for one of them??
i think i was in need for one after i decided to pull one apart to see how it worked.. tho i do have 2 more at home i think.. but are also used..
looking sweet merlin. good thing you were on top of the pipes. all the cheap chinese coolers and piping kits, and dump pipes for that matter were all shocking on the inside. overhang where welded, dags, swarf etc a-plenty. the japanese stuff is clean enough on the inside to lick if you so desire... and sometimes you do... :P
so when is my invite to come over and help...
Retail pricing was $2300.00...
You should be able to get it for under $2000.
Good to see your making some progress mate all is looking good to. Looks like it wont be to far away from getting sorted. You caught up with me pretty quick.
No way... I'm still on my interim engine. I still need to sort out the proper powerhouse :)
Suspension and Brakes are being sorted as we speak, so it shouldn't be too long before I can give it a shakedown and start tuning the setup...
Andrew,,,the chassis rails look dirty. I'm shattered.
................. I'm ashamed to say that I have actually cleaned up those chassis rails with turps and metho :):(:)
Motherf**ker!!!!
Can you afford good suspension and brakes anymore??? :/
What are you using suspension wise considering it a track car?
Rhys
Hey Andrew,
Did i read you have it started?? with the Amuse exhaust on?? please tell me how it sounds!! or record it for me?? i am dying to know how the thing sounds. it just collects a bit of dust and makes no noise at home for me..
Yeah sure is mate...
It's running on a very rough old tune on a dodgy Power FC, but it's running :)
Very deep, loud, throaty growl to it... I love it, but there's no way you could drive it on a daily basis. It's 100% cop-bait.
I tried to take a video of it for you, but I realised that my stupid Sony T200 point and shoot camera can't take any video!!!! WTF :thumbsup:
Any weight target overall of the GTR planned once the project is completed?
There's a LOT of tuning of suspension and getting used to the car before I start chasing the SERIOUS weight reduction stuff...
But after I "speed hole" all the non-structural metal panels, carbon doors, carbon boot, lexan windows, cut out the boot floor, etc etc, I'll be very happy to get it down to 1300kgs.
The last ($$expensive$$) push for weight target is a while off yet though.
Need more big signings at work to pay for my road car, mortgage, holidays, booze, drugs, etc, and way down the bottom, lowest priority is this silly fun car :D
Motherf**ker!!!!
Can you afford good suspension and brakes anymore??? :D
Rhys
Everything adds up (very quickly) :sick:
If anyone is keeping track of the cost of the parts that have been put on this car, don't tell me... I DON'T want to know :(:blush:
My brake setup (on order):
FRONT:
AP Racing CP5555 6-Pot Calipers
AP Racing J-Hook 355mm discs
Ferrodo DS3000 Pads
BF Goodrich braided lines
REAR:
AP Racing CP7600 4-Pot Calipers
AP Racing J-Hook 343mm discs
Ferrodo DS2500 Pads
Hydraulic Handbrake
Tilton Lever Brake Bias Adjuster
Yes, I know that it will be massively rear biased, but I'll see how I go. Might give me a reason to put in a pedal box and balance bar ;)
My suspension will be (on order):
DMS 50mm giant strut coilovers
Competition valving
6xxlbs front springs
4xxlbs rear springs
Still pulling the linkages together, but so far, I have:
Cusco front upper arms
Cusco rear upper arms
Cusco tension rods/radius arms
Haven't decided on swaybars yet... Probably just go for adjustable Whiteline ones to start with and see how they go.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
