Hey guys,
Just though i'd put some info in a post for anyone down the track looking, as when i searched, there was no info on exactly how much advance the VCT adds.
I was degree'ing my std cams, looking for a bad lag problem, and i pulled the VCT cover and put a socket onto the cam nut and advanced the cam manually and then re- degree'd it all
The Advance the VCT adds is 20 Degrees.
The readings i got for the std rb25det S1 cams are. (NOTE :- Don't take these as gospel please, was just a quick check over. There was some weird stuff, as both intake and exhaust seems to close 30 degrees later than the factory specs indicated..... but it was only a tiny amount over quite a few degrees, so i just put the factory number working it out of 240 degree cams as per the manual)
All TDC references on the intake cam reference the compression stroke TDC
Intake Opens at TDC (vct off)
Intake Opens at 20deg ATDC (vct on)
Max lift at 120 ATDC (vct off)
Max lift at 140 ATDC (vct on)
Intake closes 240 ATDC (vct off) see note (270 actual to totally closed)
Intake closes 260 ATDC (vct on) see note (290 actual to totally closed)
All exhaust TDC references to the Exhaust stroke TDC
Exhaust opens at 240 BTDC
50 thou lift opening at 215 BTDC
Max lift at 117 BTDC
50 thou lift closing at 25 BTDC
Exhaust closes at TDC see note (30 ATDC actual to fully closed)
Let me know if anyone disagrees.
Gary
  • Like 1
https://www.sau.com.au/forums/topic/264065-rb25det-vct-info/
Just note, the anomalities were only on closing, and as mentioned, only over the very last 15 thou odd of lift, so i wrote it off as a bad setup on my part possibly...... opening and max lift were very well defined.
Gary
I've got something VCT related to add. Not sure if this has been posted elsewhere before but if you are running a VCT head in an application where it is the VCT can't be used you should always look at locking up the cam pulley.
I had situation where my RB30DET with VCT head had issue with inconsistent performance and crap idle. As soon as I plumbed up the oil feed to the VCT gallery the engine became much smoother and the idle became very consistent. The build was ok at first but over time these issues crept in..
My theory is that the VCT cam pulley mechanism without oil dries up and can move and stick at different advances. The thinkers out there will say this cant happen because the friction in the cam shaft will always act to retard the cam pulley preventing it from advancing. Thats what I thought too..But when you think about it when you stop the engine if the cam shaft is on a lagging edge of a cam lobe it may have a tendancy to advance the cam. If the mechanism is sticky then once it does advance it may stay there for while. Not positive about this...it is just a theory..
But what I do know for sure is the engine became a lot more consistent in power delivery and idle after the VCT was reconnected. BTW it took a fair amount of playing around with the VCT mechanism to free it up even after the oil feed was returned to it...
Thanks for the info mate.
Hey, if anyone has tried, please comment.... I noticed when rotating the cam and advancing it, it was VERY stictiony (ie got stiff in multiple locations while advancing) ... letting it come back (retard), was alot smoother.....
Is this common , or has anyone been able to smoothly advance it ?? I did check another parts engine, and it was abit more sticky than mine on advance, but i figure if someone with a working car had same probs, then its as its meant to be.
I am just chasing a bad lag problem, taking till 4700 to make 10psi (to3 stage 3 turbine and .63 a/r rear) Turbo guy says it shoud be on at mid 3's and results on this site from guys with similar indicate same..... so i thought maybe vct is taking its time to engage...
Anyone offer any help / experience with this ?
Gary
Just to add some pics to this VCT repository, as its one thing to hear a description, but when i was looking for info i never saw one pic of the VCT stuff. Enjoy !
Front VCT actuator with the plate and big cam bolt removed
Back of the VCT pulley.... note the slots in the bolts holding inner to the gears....this is the adjustment possible people mention.
Inside showing where it slides onto the cam. Small inner slot is for the alignment pin. 4 larger slots are for oiling the cam as the outer part rotates on the cam when the actuator advances. Mine was scratched on the cam, possible causing my sticking problem...
Looking at cams without the pulleys
VCT oil holes. These provide the oil to the actuator and lube the cam journal. When on oil comes from one hole and turns actuator on, when off oil drains back thru other hole. (switched by the VCT solenoid) I have to assume then, when off the cam journal doesn't get an active oil feed ??
Those oil holes feed into the cam ....see the hole in the middle of the journal ....
And then up thru the cam bolt into the front cover (hence the o-ring used)
Edited by Fastrotor
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
