hey everyone...diciding to sell my Skyline but only if i get the right price or else i will be finish the project off with making my 400kw goal at the wheels GTR and show car....at the monment its all just show, as i hit a low point in the build with funds and am still contemplating on whether to finish the whole car or not....i have owned this car for over 3years and is still regestered till August...im located in VIC, melbourne S.E
The r32 GTR has had the following done so far
Full wide Body r34 conversion
R34 XENON head lights With HID
R34 GTR front bar
Nismo Clear front and Side indicators
Carbon fiber R34 gtr Bonnet
Carbon fiber mirrors
Carbon Fiber Boot Lid
Carbon Fiber Door Cards (plus standard door cards)
Carbon Kevlar Bride Fixed back Bucket seat
TAKATA race harness 5 point
Shaved door handles
AUTOLOC (USA) remote operated door poppers
R32 Led Rear lights
R34 GTR wheels
Trust gear Knob
Full Respary with Fantasy Colour (Flip from purple to Blue) almost identical to midnight purple III
Standard Boot lid also included (with deleted key hole and spoiler holes)
2wd or 4wd mode switch
4 Undercar Green Neons with switch
engine wise
Apexi boost controller
Nismo Strut Brace
Trust Turbo timer
Trust Air filters
Trust 3.5 inch Cat back Exhuast
Trust Oil Cooler
Trust Oil filter relocation kit
Trust 600x300x100mm thick intercooler (plus standard one)
Standard GTR brakes
Have recipets for all work done on BODY so far totaling $13g
Seriously XXX on Wheels
looking for $25g
will post pics up soon...coming back from painting in one or 2 weeks...just in primer at the moment
any interest speak up
Edited by bnr324
Here's photos of the car in primer... as u can see it's a one piece bodykit and door handles shaved... everything done to perfection.. except front bar has not been made a one piece to the front guards as front bar is uaually the first to get damaged....well here u go
Edited by bnr324
car is at RE Customs getting new engine from r33 gtr put in and new turbos for the lucky buyer...
so its at the mechanics atm
will be painted in 2 more weeks... so i'll have more pic then.....
Trades Welcome
  • 4 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 4 weeks later...
sorry guys... i had completey forgotten about this thread...
yea cars is painted, engine running, just finishing putting the final few little touches and wiring...
should have pics this coming weekend deffenetly as there is heap of interest from word of mouth aswell...
cheers guyz
  • 4 weeks later...
  • 11 months later...
    • And make sure the belts are tightened appropriately too.
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
