Galston to Gosford Cruise 8:30pm 17/10/2003 (Formerly Midnight cruise - Friday 17th)
Hey guys!
Anyone interested in another midnight cruise?!
Start off at midnight at your favourite carpark (the old maccas carpark)...then head up to newport for pizza and maybe a palm beach run...whatever...its negotiable :D
CHANGE OF PLANS!!!
Meet is now 8:30 at Thornleigh Macca's for a cruise through Galston Gorge and onto Gosford. This is a great drive for those who wish to go for a spirited drive and also a leisurely cruise.
PLEASE make sure you come with a full tank of fuel BEFORE arriving at Thornleigh.
PLEASE NOTE: MEET AT 8:30pm FOR A 9pm LEAVE....
Okies....Here is a list of whose coming....let me know if i have anything wrong. Not sure if alot of the people mentioned are still coming as they haven't mentioned anything since the plan change....
Coming
Mona
Brie
Tosh
Geoff
Craved
Fatz
Da_Man + friends
Supra + friends
SUPPRA
EVA00L
Mark (MRK 25T)
Darren
Jimbo
Bleach1
Maybe
Nick
Carlo
Duncan
Ian
Backup
B-Man
Ash
Benm
Mark (Mr R32 M-Spec)
Those meeting up
CS 180 – in Terrigal if we end up there for pizza :bahaha:
  • Replies 161
wat type of cruise is it? like do ya floor it the whole way or is it speed limit or running red lights or what hehe neva been on an SAU cruise due to the fact i have no car and recently got my Ps but i could get a car for that nite if its not gona b 2 hectic :D (i liv north shore) lata :D
ps i wana meet and see all ya skylines!!!!!
As a general rule, anyone is welcome to attend our meetups however there will be no running reds, no "hectic" driving or anything else that could jeopardise the good rep we seem to have built with the northern beaches police.
If you feel like coming along, meeting a top bunch of people and enjoying a good drive and some great cars then sure. Rock along.
As Blitz says, the idea of road cruises is to get out with a bunch of mates and enjoy driving. Going crazy on the roads and pulling stupid stunts is not the idea, it's a relaxed cruise not a race :D
    • I can't help with the clearance question, I've always taken my machine shop's advice on that. It is worth considering that a shop that does that every day for road cars will be looking for as good as they can get off the shelf, not perfect. If you want more careful race style "blueprinting" then you need a race shop to measure/machine the engine. I do have an opinion on line boring the block though....don't do it unless you have to. The crank centre moves higher but the oil pump stays in the same place when you line bore the block.
    • Hey that reminds me, are you changing your forum name to "The Hairdresser" too?
    • There's no figuring out with a Haltech, you literally load up the base map, plug in the vac/boost reference from your manifold to the ECU (or an external MAP) sensor, wire up an IAT and it will run pretty well out of the box. The ignition tables are quite well defined and safe enough for someone to give it a hit (although I don't recommend it if you've got anything besides the stock gear on the motor).
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
