LOL
Check out my 40 inch rims!
I like this quote the best:
"While the Patent Motorwagen used a 958cc four-stroke petrol engine generating 600W of power-less than a hairdryer-the newer version doubles that, generating 1.2kW from the rear-mounted fuel cell that drives the Roadster's electric motor." My what 150 years of technology has done. A carriage pulled by two horses has more power.... technically...
AMG has gone mad....
This is a sad day, Mercedes AMG has sullied one of its most cherished icons, dropping a 6.0 liter V8 into a camo-painted Mercedes-Benz 300SL Gullwing designed for Bathing Ape Fashion founder NIGO. Ugh.
Mercedes, What Hast Thou Wrought?
The car was built because when you're a billionaire and you got nothing better to do with your money, then why wouldn't you get the oldest auto company in the world to bastardize one of its most sought-after classics? The completely camouflaged car has been equipped with completely upgraded mechanicals including a 6.0-liter V8 and we're assuming an automatic transmission.
Some things money shouldn't be able to buy, like self-respect. We could understand if an outside tuner shop created this abortion, but for Mercedes to have a hand in this is just so wrong on so many levels.
I don t mind the design exercise/makeover; kind predictable though. 1.3KW awsoma powa!...will it chirp second?
The 300SL is appalling, luckily it looks like vinyl so it will as they say "buff right out". They were kinda tricky to drive standard, I wonder what it handles like with the new engine. :D
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
