now i'm back in the modern world with internet (albeit not a proper connection) thought it was time to upload some pics if the new beast :cheers:
I've already heard all the Hairdresser, girls car, FWD jokes insults ect haven't i mr nightcrawler......
https://www.sau.com.au/forums/topic/264095-the-hair-dressers-car/
  • Replies 51
not bad for a self propelled lifesize replica of a jelly bean... does it have any weapons?
-D
nice car :)
i was worried it'd be a two door lancer with altezza lights, 18inch cromies and a gay droid body kit :cheers:
phew!
yeah i thought i would stick to a 2.5Lt turbo instead. the Altezza light lancers were tempting.
nearly already traded it in on a renault megane cup
Looking good nick lol at hairdresser when you coming over to cut my hair
those reno's are good too from factory they boost good and handling is exceptional went for a cruise through the gorge once with a heap of skylines and none of the rwd could keep up and even i was struggling
dont even go there luke at least he got the huffer version
yeah sam have to admit i have been driving it briskly lately and haven't had any issue even at rbt's ect
liking the "launch control" too (holds it at 3500RPM in 1st as that the best RPM for a launch with reduced torque steering)
through the hills point to point it would easily out do skylines.
Andrew can vouch for the handling through the round abouts the other day
Nice car nick! :cheers:
Contemplated getting one of these for my current lease through work, but just not quite enough room for all the gear when we go away with the little one so ended up with the Liberty GT instead. Was rather impressed by the equipment list they have, nice looking german rocket!
hahaha hairdressers car :cheers:
All jokes aside, she is a nice car mate. And yes, I certainly can vouch that they go very hard - would easily crucify a stocky R33, and would toast even a pretty well set up mild R33 through the hills!
Is this comparing it against an R33 GTR V-Spec Series III? Which is about the same price bracket... or comparing with an R34 GTR within the same year? or an R32 GTR modified to the same value?
lol they go pretty good :cheers: my boss as work just got 1, let me drive it when it had just 60ks on the clock.
im trying to con her into coming to fnf drive in antics in it.
is it a new 1? the lv?
i hear the clutches dont let you do a burnout though something engages and prevents it.
does yours put the hazards on when you brake hard?
lol youll be joining these forums soon then
http://www.fordxr5turbo.com/
14.4 quarter aint bad for a fwd, lil rolling start would help em spank a few decent cars.
Edited by Inline 6
Good to see u can connect to interweb again Nick. Nice pick up....any plans for any basic mods?
those reno's are good too from factory they boost good and handling is exceptional went _ with a heap of skylines and none of the rwd could keep up and even i was struggling
...and here I thought you were taking it easy due to havin a car load :D. The Megane sports makes the cutest bov sound and they do handle pretty well through the hills, but there have been instances when their Brembo brakes may experience serious brake fade on downhill sections :) and struggle when a particular silver rwd R33 pushes it to its paces.
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
