Hi guys
I got problem today. my car was running with a 33gtr PFC and custom wire loom before. I just bought a used PFC D jetro(for BNR34). this one should just plug in and no need the 33-34 wire loom. after I swich to D jetro the car counldn't start. my tuner told me there is no pulse signal for the injectors.
and they will check the pins on monday. if the pins are all right, maybe the problem is the computer itself.
anyone got the same problem???? I hope the problem is the pins not the PFC.
PS: I don't know why the car used a 33gtr pfc before, 34gtr pfc should have same price as 33. confuse```
Edited by Nosure
why on earth are you using a BNR34 PFC on an R33?
are you sure? from memory the main ECU socket is different
there are many differences on the wiring loom (and socket is different too) so theres no way it would work
ie: you cant plug an R34 ECU into an R33 Car
what car do you have?
what model PFC do you have? (Whats the model # on the metal case)
If memory serves me correct, the R34 CAS is different... hence your problem.
Side question - why on earth would you need a custom wiring loom for a GTR running a PFC?
what CAS??
I just bought this car, I don't know why and who did it.
My english is not really good, but you will simply understand with this:
Edited by Nosure
I have a 34GTR, its use a PFC (BNR33L) before. now I change to PFC(BNR34D). and then there is no injector singal and the car couldn't start.
I guess the pin must had been changed for suit the BNR33L PFC. I hope the problem is not the D jetro computer itself.
Edited by Nosure
yeah i was about to say, theres no way it would plug in
so yeah you had a boomslang extension which converted to an R33 GTR PFC (what a waste)
id say there could be numerous things wrong
go find a local work shop who can tune skylines and get them to fix it
its too hard and complex to play interenet mechanic
OK, thanks!
the tuner tried the standard computer, but it still won't start.
So now: PFC BNR33L with (boomslang extension) start fine.
PFC BNR34D won't start
BNR34 standard computer won't start.
any idea????
Edited by Nosure
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
