Nosure Posted April 3, 2009 Share Posted April 3, 2009 (edited) Hi guys I got problem today. my car was running with a 33gtr PFC and custom wire loom before. I just bought a used PFC D jetro(for BNR34). this one should just plug in and no need the 33-34 wire loom. after I swich to D jetro the car counldn't start. my tuner told me there is no pulse signal for the injectors. and they will check the pins on monday. if the pins are all right, maybe the problem is the computer itself. anyone got the same problem???? I hope the problem is the pins not the PFC. PS: I don't know why the car used a 33gtr pfc before, 34gtr pfc should have same price as 33. confuse``` Edited April 3, 2009 by Nosure Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/ Share on other sites More sharing options...
R31Nismoid Posted April 3, 2009 Share Posted April 3, 2009 If memory serves me correct, the R34 CAS is different... hence your problem. Side question - why on earth would you need a custom wiring loom for a GTR running a PFC? Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4516978 Share on other sites More sharing options...
alpinestars Posted April 3, 2009 Share Posted April 3, 2009 from memory theres a security wire from the dash that feeds to the pfc to start the car also the cas is different and the wiring to the cas is setup different aswell Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4516993 Share on other sites More sharing options...
paulr33 Posted April 3, 2009 Share Posted April 3, 2009 why on earth are you using a BNR34 PFC on an R33? are you sure? from memory the main ECU socket is different there are many differences on the wiring loom (and socket is different too) so theres no way it would work ie: you cant plug an R34 ECU into an R33 Car what car do you have? what model PFC do you have? (Whats the model # on the metal case) Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4516994 Share on other sites More sharing options...
Nosure Posted April 3, 2009 Author Share Posted April 3, 2009 (edited) R31Nismoid said: If memory serves me correct, the R34 CAS is different... hence your problem.Side question - why on earth would you need a custom wiring loom for a GTR running a PFC? what CAS?? I just bought this car, I don't know why and who did it. My english is not really good, but you will simply understand with this: Edited April 3, 2009 by Nosure Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4517011 Share on other sites More sharing options...
Nosure Posted April 3, 2009 Author Share Posted April 3, 2009 (edited) paulr33 said: why on earth are you using a BNR34 PFC on an R33?are you sure? from memory the main ECU socket is different there are many differences on the wiring loom (and socket is different too) so theres no way it would work ie: you cant plug an R34 ECU into an R33 Car what car do you have? what model PFC do you have? (Whats the model # on the metal case) I have a 34GTR, its use a PFC (BNR33L) before. now I change to PFC(BNR34D). and then there is no injector singal and the car couldn't start. I guess the pin must had been changed for suit the BNR33L PFC. I hope the problem is not the D jetro computer itself. Edited April 3, 2009 by Nosure Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4517019 Share on other sites More sharing options...
Nosure Posted April 3, 2009 Author Share Posted April 3, 2009 anyone has CAS graph for GTR34?? Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4517284 Share on other sites More sharing options...
paulr33 Posted April 4, 2009 Share Posted April 4, 2009 yeah i was about to say, theres no way it would plug in so yeah you had a boomslang extension which converted to an R33 GTR PFC (what a waste) id say there could be numerous things wrong go find a local work shop who can tune skylines and get them to fix it its too hard and complex to play interenet mechanic Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4517442 Share on other sites More sharing options...
Nosure Posted April 4, 2009 Author Share Posted April 4, 2009 paulr33 said: yeah i was about to say, theres no way it would plug inso yeah you had a boomslang extension which converted to an R33 GTR PFC (what a waste) id say there could be numerous things wrong go find a local work shop who can tune skylines and get them to fix it its too hard and complex to play interenet mechanic OK, thanks! Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4517943 Share on other sites More sharing options...
Nosure Posted April 5, 2009 Author Share Posted April 5, 2009 (edited) the tuner tried the standard computer, but it still won't start. So now: PFC BNR33L with (boomslang extension) start fine. PFC BNR34D won't start BNR34 standard computer won't start. any idea???? Edited April 5, 2009 by Nosure Link to comment https://www.sau.com.au/forums/topic/264098-car-cant-start-after-installed-pfc-d-jetro/#findComment-4519926 Share on other sites More sharing options...
