new here, just posted in the newbie thread and couldnt find members ride thread so thought id throw it in the vic thread so if this needs to be moved else where my apologies :cheers:, got the specs and the pics so this is my ae86 sprinter.
xt130 struts, with twin piston brakes
xt130 LCA, new bushes and ball joints
TRD 5kg rear springs
custom 8kg springs up front (on there way...)
short stroke kyb excel g shocks all round
new ra40 tie rod ends and balljoints
new brake lines all round.
rest is stock except on the interior, dash mat and a nardi steering wheel.
Nice 86. Just need to paint it panda-spec and get bigger black rims and you're set :)
Don't take this the wrong way, you're more than welcome to join the forum of course, but just wondering, why Skylines Australia???? :cheers:
met afew guys down at the dyno nights, and just tonight at the springy performance one so thought id hop on here come to afew events talk some bullshit and meet new people :) also signed up to nissansilvia forums since mate from school is on there and they go to most of these events to :)
Edited by sprinter666
Welcome
Because it's the cheapest CAMS affiliated club in Victoria
edit: guess not lol
used to own a Hachirusto too. ahh good times.
mmm solid rear axle love.
BTW, wanna buy the plates BOR086 or a jdm tyte Levin front grille? i've got a couple of leftovers from my hachi chillin in my garage.
So if its stock, its got a 4AC? or have you done a twincam swap?
interested in the front grille but i dont want a cop bait car lol so i like it stock for now, nah only suspension work still runs the 4ac, and hachirusto? come round n have a look not 1 spec of rust anywhere :devil: i love it :)
yup i think so? the camera guy with the r32 correct? :D yeh thought u were sum1 else at RE customs night but met ya there to, to bad the springy motors one wasnt as big of a turnout :blink:
yup i think so? the camera guy with the r32 correct? :( yeh thought u were sum1 else at RE customs night but met ya there to, to bad the springy motors one wasnt as big of a turnout :nyaanyaa:
Yeah thats me, haha!! All good then. Yes the RE Customs is always a big turn out as Springy Motors only started doing Dyno days at the start of this year.
Welcome to SAU!
Love the Watanabe's on the AE 86, looks mad!
You gota Panda it up. :D
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
