Hi Guys,
my mate is selling his r33 s1 mines ecu, very mild tune. Came of r33 s1 manual, pod filter, 3" exhaust, fmic.
not moving from $300 as its a safe tune.
pick up welcome from sydney. delivery is $10 express post.
Any more info on the tune? Hows the fuel efficiency and how was it mapped?
fuel effeciency feels the same as it was when it was stock only because in stock i kept hitting r&r and using alot of un-tuned fuel...
this map seems to take out all flat spots, but does go really well compared to stock i personally love it.
idles alot smoother to my stock ecu (after i got exhaust)
<br />fuel effeciency feels the same as it was when it was stock only because in stock i kept hitting r&r and using alot of un-tuned fuel...<br /><br />this map seems to take out all flat spots, but does go really well compared to stock i personally love it.<br /><br />idles alot smoother to my stock ecu (after i got exhaust)<br />
<br /><br /><br />
ah ok,sounds good. would it need any dyno tuning if i put it into my car? and how much power did you make with it?
<br />please research "mines ecu" alot of information on them, its just a chipped ecu, which i prefer as it maintains all the safety features of the stock ecu, which in my beliefs the jap engineers seem to have got right.<br />
<br /><br /><br />
Hey man, ok Im pretty interested here, but just want to know, do I need to have a fmic on my car for it to work properly? (since yours has been tuned for it). wud i need to get a front mount for my car run alright?
With a mines ecu are they model specific or can u run them on both series 1 & 2?
Also could u post the Mines serial number in the first thread so i can look up the specs for it as i have one tuned for massive mods and am interested in yours.
cheers Davo.
davo where is the serial number found? also could you advise how i can search the specs too for future reference?
all the specs are on the mines site (mite need to google/translate some of it). Umm a mate is using my ecu atm so i cant check but from memory it has a gold and silver mines sticker on it and on one of those is a serial or reference number. I remember trying to look up stats ages ago its a bit of a hassel tho.
ill get the details soon, in the meantime do you mind posting the link to that section of the sitE?
http://www.mines-wave.com/
email them the Mines Plaque serial number and they will email u back with something like this:
Thank you for your email and query.
ECU Serial number shows the following tuning specs:
1. Removed the Speed Limiter
2. Reset the injection and ignition timing
3. Expanded the rpm from 7700 upto 8200 within the Rev Limiter
4. This VX-ROM is for CA18DET, MT, vehicle year (May.1989 - January.1992).
Oh forgot to say on that link click the english version banner then click the inquiry banner then click the Q3 link. Then all u have to do is fill in info of ya car and they'll get bak to ya wif whats done to that ecu.
Also did u hear any ping on 98 octane fuel? and when u installed ya mines ecu did u check your base timing?
Edited by Driftin~Davo
I've emailed them twice with no reply, are you sure these guys understand english?
Either way specs or no specs from the japs, the car was running the mentioned above with safe a/fs.
By safe A/F's did u measure using a wideband meter with a 3rd gear launch to redline on aus fuel 98 octane?
Also would ya mate b interested in trading with my mines? I can get the specs for ya but my mate that is borrowing it said runs way to ritch with stanard injectors.
  • 4 weeks later...
    • Jap premium will be 100 RON. You should use 98.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
