Hey,
Went to roof rack world on the pacific highway looking for a roof rack......after I explained what the car was. . . they looked at the fitting space under the black cap. Saw the bracket and bolt points and said No.
Clearly they can have roof racks so does anyone know a model and name of one that fits in with little or no hassle.
Getting a tow bar just for MTB is to costly and the roof racks are a better option for me. .
Thanks
Jules
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/
There's a Thule(or watever it is) distributor in Artarmon...they have done both mine and Andy's.....price was about $360 from memory.
Roof Rack world in Artarmon...Dickson street me thinks
Do you happen to know the make and model number. . . the Kiwi ones look good for $300'ish. .. . but local is better if I can. . got any pics of yours. . .
Jules
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4518493
Jules
nup no pic's.....they are Thule....model number I don't know but if you drop in there they will be able to show u the bit's they used to make it up....fit up looked pretty good....not bodgy in other words.
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4518512
For what it's worth (and from what I can gather), the Japanese part number is "KIT4716" for the bars & mounting bracket as a set.
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4519980
Hi guys,
New to the forum and looking at buying a Stagea soon so will be posting a few questions about the car before I buy :nyaanyaa: .
Just a question about the roof rack placements, is it only front and middle you can place the racks or is there a mounting point further back closer to the boot?
Cheers.
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4520580
front and middle only yes
a pity that because it makes it difficult to carry a kayak unlike c34 stag
Thanks for the reply.
Bit of a pain as I would like use the rack for long items. Looks like a towbar is in order.
Cheers.
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4520827
They are far enough apart that they will support a 11 foot windsurfer or 2 so they are not too bad. The good thing about where they are placed is that you can still open the tailgate fully with items on top.
Cheers
Andy
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4520861
hmmm, I'd been thinking of changing the rs4s for a m35 (the wife wants an auto...), but won't after reading this post.. I use the roof rails on stagea for carrying looong things, and the rails on the m35 look useless.
I've also made a T frame that comes up from the tow bar, so I attach things at the front, middle, back on the roof, and beyond from the towbar - ie I've carried 8m long steel poles home on the stagea, and it does 6m with ease... And 2.4m*1.2m sheeting fits on the roof bars withno problem.. I couldn't do any of that with a m35!
Ian
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4521546
  • 5 months later...
Finally some better weather, tried out the soft roof rack setup i had on my old car. Damn that long flat roof is a pain but we got the kayak on there ok, lucky i dont live to far from the beach. May switch to trailer setup in future, ends up being a lot easier....
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-4861307
  • 1 year later...
Hi Guys,
Sorry to reopen an old topic, but I am looking to get a roof rack on my M35 and have had the same difficulties finding a suitable one.
What model/part number Thule roof rack is it that people have been installing on their M35s, and what have they used for the riser?
Any help would be greatly appreciated.
Cheers,
Brendan
https://www.sau.com.au/forums/topic/264150-m35-roof-racks/#findComment-5525918
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
