Gday guys,
I have loads of R34 parts to get rid of,
Pref Pick up.
0411887820, or Pm me.
1. Straight through 3' pipe- $30
2. Stock Turbo (75xxxks) + Dump pipe 2.5' $400 the lot.
3. Greddy adj cam sprocket - $100 20.xxx ks old
4. Stock R33 series 1 Throttle body- $30
5. Rb25 Neo injectors - $80
6. Variety of piping - offers
7. Stock Camshafts - $150
8. Stock R34 Radiator - $20
9. Brake Discs -$50 all four.
https://www.sau.com.au/forums/topic/264152-lots-of-r34-parts/
No headlights, i'm not wrecking the car guys, THE PARTS THATS FOR SALE ARE CLEARLY LISTED IN THE TOPIC.
Please read before post or pm.
TURBO, DUMP, CAM GEAR, RADIATOR are SOLD.
Straight pipe, Injectors, pipes and brake discs are still available.
  • 1 month later...
  • 3 months later...
Massive Bump lol,
Sorry guys i forgot about this thread.
Stuff left for sale:
1. Stock R34 GTT suspension
2. Straight through pipe
3. All the pips + rubber hose on that pic
4. Injectors
Brake discs sold pending payment
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
