Gday guys,
I have loads of R34 parts to get rid of,
Pref Pick up.
0411887820, or Pm me.
1. Straight through 3' pipe- $30
2. Stock Turbo (75xxxks) + Dump pipe 2.5' $400 the lot.
3. Greddy adj cam sprocket - $100 20.xxx ks old
4. Stock R33 series 1 Throttle body- $30
5. Rb25 Neo injectors - $80
6. Variety of piping - offers
7. Stock Camshafts - $150
8. Stock R34 Radiator - $20
9. Brake Discs -$50 all four.
https://www.sau.com.au/forums/topic/264152-lots-of-r34-parts/
No headlights, i'm not wrecking the car guys, THE PARTS THATS FOR SALE ARE CLEARLY LISTED IN THE TOPIC.
Please read before post or pm.
TURBO, DUMP, CAM GEAR, RADIATOR are SOLD.
Straight pipe, Injectors, pipes and brake discs are still available.
  • 1 month later...
  • 3 months later...
Massive Bump lol,
Sorry guys i forgot about this thread.
Stuff left for sale:
1. Stock R34 GTT suspension
2. Straight through pipe
3. All the pips + rubber hose on that pic
4. Injectors
Brake discs sold pending payment
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
