sorry guys, found an earlier thread that explains most of it...
( http://www.skylinesaustralia.com/forums/sh...=&threadid=1693 )
can anybody tell me if the diff's are different, I know the brakes are too, what about the suspension?
It's just I found a sweet GTS-t but it's not a Type M and I'm wondering if I should hold out?
  Quote
Ed, I'm not sure if the diffs are the same, but definately go for the Type-M... just for the brakes alone I'd get one.
With the spoilers... all options for both, so not all Type-M's have them.
  Quote
cheers, so it's just the brakes really then?
Yeah, the Type M is really just: wider standard wheels, bigger brakes, and airbag/LSD/spoiler options... thats all the important stuff.
  Quote
Originally posted by Pekatu
mine is supposedly a type M it has air bag instructions on the drivers sun shade, but a normal wheel.
are you saying you can get turbo r32's without a LSD?
I think they all have LSDs (they'd have to...) but the ones in the Type-Ms were different, or there was an option for a different one?
  Quote
Originally posted by williamc
airbag on r32 type M?? Think you may be mixed up with r33.
Also, side skirts I dont think are standard on non-type M 32's
Oooookaaay... airbags WERE OPTIONS on HR32 Skyline GTS-t Type-M`s from 8/91 on.
Believe me, I don`t post stuff unless I triple check it.
Please guys, read the posts before replying. Just because you`ve never seen something, it doesn`t mean it doesn`t exist... especially on Japanese Imports!
So this makes my car a mongrel :(
Got all the type M gear minus skirts and a GTS 4 front bar (guessing accident by previous owner)
BTW has anyone ever seen a GTS-t with steelies (as mentioned in the link above)? Particularly amusing when the GTS non turbo has 4 stud alloys!
I don't think there were different brakes though. All 32GTS-t's that I've seen have the same 4 pot brakes unless they have been upgraded to R33 brakes or better by the owner. Though if the brakes have to fit behing steelies than I wouldn't be surprised to see it.
Im pretty sure my r32 is a Type M, it said on the auction report from Japan.
And it has the airbag warning label on the sunvisor, but my wheel has been changed to a sparco race wheel.
Williamc, the front brakes (4pot) are bigger than the rears, you can see 2 pistons from each side.
My car came without sideskirts and rear pods, pretty sure they were an option even on Type m.
all the R32's have the AIR BAG instructions on the visor but dont have an AIRBAG (bit dodgy) anyway my 32 has hicas,ABS and all the other shit including the HUGE ARSE brakes which failed. :D
STUPID ABS Crap
While on that topic anyone know how to remove the full ABS?????
Let me know
Hey Guys,
Got this from the book "The Sky is The Limit" ( Couldn't find the name of the author, so can't pay my respects :D ) Apparently taken from a Japanese Skyline sales brochure.
"The Type S is based on the GTS, and has alloy wheels, HICAS and the sport type steering wheel. The Type M is based on the GTS-t, and has 16x6.5 alloy wheels, HICAS, and the sport type steering wheel. The Type M, Type S and GTS-t have HICAS, the regular models don't."
"Options: Climate air conditioning, Electric front spoiler, Sunroof, Cruise control, Premium audio ( Kenwood / Alpine / AddZest), Rear spoiler, "Bug eye" headlights, Alloy wheels, Permium brake package."
Hope that helped!
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
