  • Replies 41
hey guys n girls ive wrecked one of my 32s, ive still got heaps of shit left over
engine cross member $100
front lower control arms $ 100
upper arms new nolothane bushes $ 50
mint vicous lsd $150
Mint manual tailshaft $100
axels $70 for the pair
5 stud hubs $100
mint boot lid, white, no spoiler $ 70
passanger and drivers doors with petty much everything $100 each
dash cluster 180 xxx $ 80
interior eg front rear seats $150
extreme 6 puk clutch, still fine.. about 50-60% meat on it.. $150
r33 rb25de head $450 has new exhaust studs
type m stockl front and rear bumper ok condition $100 bucks for both
custom castor rods with new nolothane bushes $70
stocko suspension $ 150
front coilovers.. unknown brand no leaks $100 bucks
ive got heaps of random stuff laying around so if you need something drop me a pm or msg me on 0433 690 019
im in morphett vale, adelaide
cheers, Nathan
wanting interior trim near rear window on both sides for r32 gts-t not broken
everything still here.. Now have a white bonnet, white rear bar, purple rear bar, stock dump pipe and front pipe.. Everything has to go!
hey just wonderin if u got the wirein harness that goes from the ignitor box to the computer and injectors? i just need that wirein harness
na sorry buddy i dont..
hey mate u get my first post u should feel lucky i need left blinker radtatior and mushroom filter if u got one and a low klm cluster
ive got a cluster with 180 on it..
im after the hubs...will they suit a s13 stud conversion?
if so ill have them
im pretty sure the the rear ones will.. dont think the front ones will.. do a bit of a search and get back to me.. ill give u the handbrake assembly for free if u buy the hubs
got any pictures on the front&rear bar?
looking for r32 gtr front bar with lip!!
i have one which im willing to sell some time soon, how much do they roughly go these days?
Edited by silbastian
heyy,
im looking for a 92 GTST passanger side front guard and passanger and middle air vents in good condition. any chances?
Thanks heaps :(
na sorry buddy, some gaurds but they have dents n shit..
  • 4 weeks later...
Hi, was the car ABS-equipped? I am after non-abs brake lines that are connected to the master cylinder - there are three of them; I am after the one that goes to the rear of the car (it's pretty shirt) and the one that goes to the driver's side tyre well.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
