when i did mine we took the subframe to Noltec, they burned out the bushes as trying to pull out the old ones is a pain.
You use a blow torch and do it in an open area and try not to breath in the fumes.
Then got made up new ones as they did not have the kits for my car yet and put them in,
Matt
i did mine over the weekend.
mine came out of a 32 so they where old and the alloy casing expands overtime welding the bastards in.
took about 15mins on a couple each side then an hour each on the other wich have a dual case.
i cut the centres out with a hole saw, heated them up and then hit the casing with the air hammer and eventually got them out with minimal damage.
trying so hard not to damage the frame itself with a air hammer is hard. unfortunately i couldn't fit it in the press.
if i was to do it all again, i'd just man up and give it to a shop with a press, i have a spare so i might do that.
anyone know what happens if you put bushings back in the damaged case?
cheers,
D
Edited by 32_Dave
the other bushings on the back i lit it with the torch and made it burn out as said earlier. but what i did afterwards was to get a hacksaw take out the blade push it through the hole and the attach it back together and cut the metal part and it just falls out.
i know the subframe arent much different so i just wanted some heads up its not hard just the technique
Edited by jnr_chin
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
