when i did mine we took the subframe to Noltec, they burned out the bushes as trying to pull out the old ones is a pain.
You use a blow torch and do it in an open area and try not to breath in the fumes.
Then got made up new ones as they did not have the kits for my car yet and put them in,
Matt
i did mine over the weekend.
mine came out of a 32 so they where old and the alloy casing expands overtime welding the bastards in.
took about 15mins on a couple each side then an hour each on the other wich have a dual case.
i cut the centres out with a hole saw, heated them up and then hit the casing with the air hammer and eventually got them out with minimal damage.
trying so hard not to damage the frame itself with a air hammer is hard. unfortunately i couldn't fit it in the press.
if i was to do it all again, i'd just man up and give it to a shop with a press, i have a spare so i might do that.
anyone know what happens if you put bushings back in the damaged case?
cheers,
D
Edited by 32_Dave
the other bushings on the back i lit it with the torch and made it burn out as said earlier. but what i did afterwards was to get a hacksaw take out the blade push it through the hole and the attach it back together and cut the metal part and it just falls out.
i know the subframe arent much different so i just wanted some heads up its not hard just the technique
Edited by jnr_chin
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
