Not trying to steal other peoples ideas but brain stormin more like, can u please post a pic or describe your intake set up.
i have been tryin to figure out wat i can do for ages.
i have a rough idea but not sire of prices where do get it done, etc.
i drew this up in paint, its kinda wat i want.
cheers
https://www.sau.com.au/forums/topic/264274-intake-setups/
hey mate this is what i've got, just a custom checker plate and perspex box with cold air feed underneath. just a heads up you pretty much need to keep the intake pipe stock coz it needs that box thing thats attached to it, thats why i stuck some checker plate on mine just to neaten it up a bit. good luck with yours :D
https://www.sau.com.au/forums/topic/264274-intake-setups/#findComment-4520785
post a pic of your CAI setup darrell.
stock airbox with a highflow filter (K&N) works well. that or a setup similar to that one, but maybe with an enclosed box. a few peeps on here make their setups and sell them as a kit
https://www.sau.com.au/forums/topic/264274-intake-setups/#findComment-4520996
gday,
NSM033, thats pretty much what im think of, dont no bout the checker plate though, it isnt a show car, haha. see wat happens.
yer i sused out that box thing, im gonna have to buy or make an adaptor for it, and i really like the idea with the pipin up through guard, half hour job this wkn i reckon. can get a fella to make the checker plate up at work on arvo shift, might as well make it look alright.
thanks fellas
https://www.sau.com.au/forums/topic/264274-intake-setups/#findComment-4522749
cheers for the good comments guys :D ... all made all at home did the checker plate just with a jig saw and blocks of wood in a vice and a rubber mallet. good luck with yours GTS25_R33 keep us posted and put some pic's up when it's done
https://www.sau.com.au/forums/topic/264274-intake-setups/#findComment-4522768
I wanted cold air and couldn't be bothered making a cold air box... so I put my intakes on the other side of the engine bay.
picture003az4.jpg:)
I used to run this setup on another Skyline I owned. At the bottom of the airbox is a hole that allowed air to enter from the bumper duct lik NSMO33's.
I highly recomend the metal intake pipe and this Unifilter, they sound awsome. (scares animals and small children :P )
Edited by screamin'
https://www.sau.com.au/forums/topic/264274-intake-setups/#findComment-4523637
hey screamin...
would there really be much difference with the metal intake pipe compared to the plastic?
and what type of piping did nismo33 use for the funnel...
i think i might spend a day and do the cold air upgrade..
Edited by j-qual
https://www.sau.com.au/forums/topic/264274-intake-setups/#findComment-4552559
The metal pipe make the intake noise resonate. Sounds awsome. Plus, it has less turns in it than the factory plastic one.
Seems to floe good, as the car has always gone very hard for a 2ltr. The new owner seemed very impressed when he first gave it a tickle.
https://www.sau.com.au/forums/topic/264274-intake-setups/#findComment-4552644
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
