to steal a stolen thread,
can any one point me in the right direction for doing this for the vipec, i dont have the ecu yet, and probaly wont until engine is built, but would like to get this sorted before it goes together,
thanks
oh right - well since its only 1 vac signal you require (unlike the dejetro which needs two) i think you can get away with it being off the balance tube
or you can do what i have done - put a nipple into runnings 3 and 4 and then T them together and run that to ur vipec
Have had BOTH setups on my 400+ rwkw GTR and noticed no difference to the running of the engine. Initially set it up with the PCV vacuum port (PCV removed) and a tee to run to each of the MAP sensors. Then once I removed the inlet manifold to run a phenolic gasket I drilled and tapped the fittings in as per the Apexi instructions. Wasn't difficult to do, but I have not noticed a difference in the running of the engine (I datalog everything in the car using Datalogit at the track) so I don't really understand why you wouldn't just install via the far easier T-piece method?
