Hey guys, I've trying doing a search and nothing useful came up.
My 34 was always mechanically fine, serviced every 4-5000km's. Then one day I get back from holiday after 10 days of not driving it the battery is dead, which is understandable. I charged it up back to full. Multimeter read around 12.8-13V.
-It was fine for about a week. then as of a few days ago, it wouldn't turn over. Radio, electronics etc work but the car just clicks. Tried changing with another battery with full 13V power from an S15 and it started, but very weakly and it struggled to turn on but it did.
-Switched it off, then on again, same problem, it tries to turn but it just clicks, turns the fan a little bit etc, but no dice.
-RAC roadside said I needed a bigger powered battery around 450, but I don't think this will solve the problem.
lead me to the next thing it could be, being injectors, I ran through some octane booster and injector cleaner into the fuel, no good. We havn't tried pulling out the injectors and physically cleaning them yet. And of course the starter motor could be gone.
Bit strange how everything is fine then magically it falls to shit one fine day.
So my problem could be, battery, injectors, alternator, and/or starter motor. A mechanic I was speaking with over the phone said it could be battery with dead cells, but 2 different batteries having dead cells is unlikely.
When it gets jump started it will turn over okay. So has anyone got any ideas for me? To clarify, what it does when I'm turning it on without jump starting is a slight humming, tries to turn over, then just ticks..
Cheers guys.
https://www.sau.com.au/forums/topic/264303-car-wont-start/
Cheers guys.
sounds to me like its your alternator.
https://www.sau.com.au/forums/topic/264303-car-wont-start/#findComment-4519282
Cheers for the reply Sam. I thought that, but the battery is actually holding it's charge. It stays around 13V. We left it overnight and it was that same voltage. If it was the alternator wouldn't it have lost it's charge?
I think starter motor, but yea just wana get more feedback before I got waste anymore money on it.
https://www.sau.com.au/forums/topic/264303-car-wont-start/#findComment-4519297
Your starter motor is drawing too much current.
Test the voltage live while someone is cranking. Shouldn't drop any further than 9V. Also make sure the power lead to the starter motor is not broken or loose. Make sure the earth cables are good also. Poor terminal contact or poor earth will cause the same issue.
When you jump start the car the current cycles through the booster vehicle or battery. Therefore you can afford a small current drop in the circuit and it will still go.
Your problem is Connection or starter motor. Nothing to do with alternator and absolutely nothing to do with injectors....not even sure how you came up with that idea.
https://www.sau.com.au/forums/topic/264303-car-wont-start/#findComment-4519571
Well my mechanic friend and RAC was right, the battery was stuffed (both of them!). They must have had some dead cells in them (the other spare I tried was in a crash that flipped a few times which probably damaged it). And my Panasonic battery came with the car imported, so god knows how old it is, although it was still putting out 300 amps in a test done at Auto Pro today, and the guy didn't think there was any dead cells in it.
Just went out and bought a 300amp super charge battery and it started up like new first time.
So yeh, $100 fix, pretty happy. :nyaanyaa:
Edited by Magic
https://www.sau.com.au/forums/topic/264303-car-wont-start/#findComment-4520405
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
