Hi, just selling a range of parts to suit an R32 GTR, these parts were on the car which made 240awkw with this set up.
I have 2 x T25 turbos (I think)
specs of the turbos are,
M24 Garrett, 0.53 inlet and 0.48 on the exhaust side
The number on the id plate of the turbos read T702987-3
Turbos have done about 30,000k one has slight shaft movement and the other has virtually none. Both spin freely and were in perect working order when removed from car, only changed due to upgrade. I was told that these turbos are the standard item fitted to the R34GTR's. I can tell you that 240kwatw is about all you will get out of these turbos, they have vertually no lag and are very strong through the midrange, but they do run out of steem up top. By about 6000rpm in third gear I noticed the power flatten out. Car ran mid 12s with these turbos. They are a good upgrade from the standard 32/33 gtr turbos as they are steel wheel, not ceramic so they wont break.
After $400ono
Also have standard R32 GTR intercooler $250ono
Turbosmart 2 stage boost controller $80ono
Standard R32 GTR injectors and fuel pressure regulator. Make an offer?
Injectors need service.
8 x standard GTR coil packs. Make an offer?
The two extra came with the car when I bought it, the origional 6, at least one is faulty, car had a miss with these fitted, dont know if there is a way you can check to see which ones are good.
R32 GTR Mines tuned ECU $200ono
EMS ECU with wireing harness, this was piggybacked to the origional ECU in my car. This is an old model EMS but might be useful to someone,
$250ono
Origional GTR intercooler pipeing as shown in pics, $40
Apexi pod filters attached to standard air flow metres. $100
Air flow metres appear in good nick dont know how to check them and they were never functional in my car as it always ran map sensors in the time I have owned it.
Cusco front strut brace, $60
Blitz to atmosphere BOV with custom made (looks abit dodgy but works) 2in adaptor. $80ono.
Items are located at Minchinbury, in Sydneys west, Im a stones throw from WSID. Im happy to post the smaller items at the buyer expense, the larger ones might be too expensive but Im happy to try and get a price for you.
Any questions or if you are interested in anything, just give me a call,
Moray, ph: 0414 355 383
https://www.sau.com.au/forums/topic/264330-r32-gtr-parts/
Injectors need service..
What are you thinking for these?
Ones in good nick go for $200ish or....
https://www.sau.com.au/forums/topic/264330-r32-gtr-parts/#findComment-4520898
hi, pretty interest in boost controller
is that a Dual stage one? how about the condition, and workin order? any faulty
cheers
Boost controller was in full working order when removed from car, has since been kept wrapped and protected. SO should be in full working order, these are pretty basic items, cant imagine having any problems with them, also comes with red boost switch. The switch changes from 1st setting to second setting, so yes it is a duel stage item.
Thanks.
https://www.sau.com.au/forums/topic/264330-r32-gtr-parts/#findComment-4521445
  • 3 weeks later...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
