Has anyone seen this car?
http://www.drive.com.au/used-cars/NISSAN/S...433705&pt=1
I saw it today its on parramatta rd homebush across the road from the honda dealership.
I just want to know if anyones seen it and can comment on its condition because i saw it today and really liked it. its pretty cheap for a manual n besides having no leather and a bose system its got the brembos and the display, as well as a somewhat civilised bodykit lol.
Im pretty keen to go buy it but next time i go what should i look out for?
cheers.
https://www.sau.com.au/forums/topic/264334-thinking-of-buying-this/
Have you driven any V35's before or is this your first V?
Remember don't rush in, keep shopping around. Drive a few of them even if you can't afford the one your driving at least you'll have a better idea.
Best idea would be take someone with you who has a V35.
Post up a topic and see if some near you can come with you to have a look :wacko: Everybody is nice here :)
yer ive gone and seen it in person and it seemed pretty clean.
yer its going to be my first V so i have limited knowledge of what to look for besides different shades in the colour and all the panels lining up.
I wanted to check all the electronics such as the power windows n stuff but flat battery.
wat else shuld i be looking for?
brake pads or brake rotors condition, all lights working (specially the footwells or door step lights), underbody condition (scrapes and etc), headlights or fog lights housing (there could be a crack as its a common issues with 03's), and test the door lock with the remote couple of times when you are inside the car and observe.
thats just for me, you can probably get a discount if anything..
ogz got everythin pretty much...
main things i would say are windows, central locking, all lights work, check for brake squel, listen for knocking sound outta rear axle, mm thaz all i can think of atm.. but like any car u buy jus giv it a thorough once over... n dont be afraid to haggle or get them to throw in extras, its a buyers market :D
main things i would say are windows, central locking, all lights work, check for brake squel, listen for knocking sound outta rear axle, mm thaz all i can think of atm.. but like any car u buy jus giv it a thorough once over... n dont be afraid to haggle or get them to throw in extras, its a buyers market :thumbsup:
My only comment would be that if the dealer can not add more than 2 photo's and very little writing on the Website then he really hasn't got a clue.
Would of thought he could have supplied a bit more detail...
Other than that... all the advice has been good, all stuff that all cars should be checked for.
Additionally, listen to V35_Paul and shop around, get the feel for a few, drive them all and do not buy the first you see.
yer ive been in a few but never driven any becuase im not that confident in manual. ive been practicing in my mates civic Type R but yerh still not confident enough.
Also the last one i checked out the guy told me its common for the brembos to squeak because of the ceramic material but it goes away once it warms up. is this true?
but thanks for the advice!
hmmm, yeah check over everything, tyres, brakes, lights, also, you have to take it for a drive, i never buy a car without driving it, if you dont drive it you wont hear or feel alot of things, obviously turn the radio off, but when driving let go of the steering wheel, does the car still drive staight or does it turn? listen out for any noises, may be clonks (which is normally suspension) or other things, you will know if it doesnt sound right,
if the guy said the brakes arnt noisey when hot, then take it for a big drive, warm them up, make sure he isnt full of shit,
and defently check under the car, make sure the rails and stuff mounts what ever it might be doesnt have big dents etc....
or you could always get racq to do a inspection if your unsure,
Hope this helps
Hope this helps
For sure. get the RAC to do an inspection. it cost abit $200+ if i remember right. but they go over it with a fine toothed comb.
Take it for a long drive. Make sure you drive it and not the dealer drive it for you. I hate it went they do that "Wankers"
As for Brakes squeaking because of the ceramic material, I doubt that the V35 had that option so that would be a Salesperson without a clue, lying or just plain wrong!
Unless you buy a top of the line Porsche or similar, you will not get Ceramic Brakes.
Squeaking Brakes can be minor and easily fixed, scored or bent discs with cracks can not without a bit of cash thrown at it. Calipers that have worn or stuck seals are also a bit painful.
I think you may need to continue the research on the car itself and be confident with both your knowledge and your manual driving skills. Then you will see when a Salesperson is full of it.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
