My V came with a DVD player from Japan, mounted in the boot connected via RCA'a, it plays DVD's on the OEM screen no probs but I'm looking at a local replacement as the wire harness plug is damaged and the power wire drops out every now and then. The contacts on the rear of the player are loose which appear to have happened due to the location, (velcro to rear boot carpet), I would say it has happended from being moved and twisted to different angles using the boot space for other things e.t.c
What make/models DVD player are you all using/recommending? should be a quick fit as the RCA's and wiring is all there. Ill just work on the mounting a bit better.
https://www.sau.com.au/forums/topic/264378-new-dvd-player/
