FOR SALE 1994 R32 GTR skyline
Gunmetal Grey Duco
Croydon racing developments and perry engineering played a part supplying and building the engine!
aprrox 15000K's since rebuild
R33 Block (chemically cleaned, rebored and honed, surface ground and crack tested, tunnel bored 7 main tunnels)
R33 Crank (crack tested, machined and balanced)
Race series conrod and main bearings
Forged Pistons
Rebuilt Head (machined, pressure tested)
Tomei oil restrictor
ARP head stud kit
ARP rod bolts
Custom 7.5ltr sump with tomei baffle
Complete tomei gasket kit (including metal headgasket)
*engine has alot more bit like new welsh plugs ect all listed on receipts*
Gates timing belt
Tomei Cams
OS giken cam gears
N1 oil pump
SARD 700cc inj
K&N element filter
Stainless engine pipe
Stainless dumps/front
Full 3inch system (very quiet but gives a nice note)
R34 BB turbos
Remapped ECU
NEW fuel pump (was told its a GTR pump but sounds a bit loud to be a stocker)
engine bay has been cleaned up was polished bits n bright red bits but removed nearly all pipe works covers and have now been painted in satin black engine enamel i even replaced the pod filters with a stock airbox and new element filter, just looks alot neater imo
Currently making 280rwkw @ 15psi (this engine was making 370awkw with hks turbo set up unsure what turbos it was running)
dyno sheets for both
New extreme clutch and machined flywheel (with new master and slave cylinder)
5 speed gearbox (receipt for being stripped down and checked, replaced shift keys pivot ball and 4th gear syncro)
Tein coilovers
Whiteline Swaybar nolathane link bushs
all New nolathane bushs for rear arms (not yet installed will come with car)
R33 GTR Wheels
New slotted DBA rotors
New pads
Tint
Alarm/immobilser
Aftermarket steering wheel
Switchs for ABS, RWD and thermos
Torque split controller
Digital speedo/0-400 timer
TKO 300+ speedo
this car comes with many modifications and many replaced parts, Receipts for nearly all the work that has been done including the basics in past years like cv boots/steering rack boots ect all i wanted to do to finish her off was Z32 AFM's a bigger fuel pump and i would recommend -5's and she will be a weapon!
this took me more then 6 months to find and for ppl who know me and know how much of a impulse buyer i am they will realise i waiting for something amazing this time! selling due to finances, i work at holdens and will be going back to day shift but it maybe 1 week on 1 week off which will cut my pay rather badly but i want to clear my debts and hopefully buy a block of land in a new development area near me so clear this loan i should be able to scrape through for the land :s i dont really want to sell but sometimes you gotta make sacrifices :nyaanyaa:
Car is located in Adelaide (northern suburbs)
asking $22,500
PM me if interested!
Edited by shy_s6
https://www.sau.com.au/forums/topic/264393-for-sale-94-r32-gtr-gunmetal-grey/
  • Replies 60
Hi,
I'm trying to get in contact but can't because I just signed up here and need to get 10 posts :)
will make an offer as soon as i can get in contact, im in perth, finances all in order just looking for the right 32gtr.
Hi,
no drama's bud she is still for sale many offers but nothing that will help me out finacially
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
