Hey Guys,
I'm thinking about buying a Skyline 1989 GTS-4, im new to the skyline scene so yer i need to know
what a good price is and what i need to look for when doing the exception. I'm also going to have
a mechanic look at it if I cant seem to find anything wrong with it.
The car as stated before is a 1989 Skyline GTS-4.
4 doors
Turbo
120*** Km's
Auto
The guy is asking $7000 but i knocked him down to $6000
Just want to know your guys opinion on this car and if this is a good price.
Also a question for the people that have a GTS-4 who is your insurance company?
Thanks :nyaanyaa:
https://www.sau.com.au/forums/topic/264395-1989-skyline-gts-4/
ok ive found and read the " New To The Skyline Scene?" topic and read most of it and found what to look for when
buying a skyline it was quite the good read.
But im still stuck with wondering if I'm paying the right price for one?
So a little help here guys with if its good value or not would be great, i will be getting some photos of the car tonight and will be
chucking them up so you can have a look at the condition of it.
Cheers
Redbook tends to put (sometimes rather unrealistically) rather low values on most cars, but auto Skylines are generally worth a lot less than the manual ones. I imagine an auto GTS-T or GTS-4 w/ RB20 would also be extremely slow, hence making them cheaper.
I have a 32 4 door GTS-4, they are not super quick but they are a nice car...i have a 34 turbo on it and arc side mount with exhaust...very bad down low but better over 3-4000 rpm. for what i want it for its perfect (even though i have an RB30 block on the work bench at home) i also pay $1100 a year for full comprehensive insurance with Famous
