I've just been going through the suspension on my DR30.
Been changing bushes to Nolathane and fitting Koni Shocks.
Noticed that the lower ball joints were knackered and they seem to be a push in fit.
Suspension place is trying to find out if the joints come complete with lower arm (which they suspect is the case)
Can anyone suggest if this is the case or if there is a better option to replace the balljoints.
https://www.sau.com.au/forums/topic/264450-dr30-front-suspension/
QUOTE (OUTATIME @ 6 Apr 2009, 08:25 PM) 1/2 asked quote
r30's lcas r the same if thats any help
Sorry didn't understand your reply
Don't know if I'd want to compete on Taiwanese copies
r30 (aus delivered 4 door) lower control arms r the same (probs all 30s r?). i have a pair in my dr30 cos the original dr30's balljoints wernt the best.
would b easier to find a decent pair at a local wreckers. if didnt want just renew the ball joints..
Edited by OUTATIME
"Don't know if I'd want to compete on Taiwanese copies"
I have 2 sets of these. They measure exactly with the genuine article, thickness of material and all.
The genuine articles; Nissan part RH 54499-01L00 & LH 54500-01L00 are still available at about $450.00ea, but possibly ex Japan.
You don't like Taiwanese items, try the brand new items from Rare Spares, all made in Taiwan and there is no after market replacement for the lower ball joint.
Your call, but you did ask for our advise.
Maybe next time we should just tell you to F@#k OFF! You be happier then????????
Geez Dennis mate what's up your nose?
You still tired from shuttling Fire Fighters?
My appologies for expressing a reservation if it upset you so much.
There was nothing directed towards yourself so chill.
I've already taken your advice and ordered a set of copies yesterday.
Genuine Nissan was $250 a side
Thanks for the help...You happier now?
Edited by R34
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
