Spraying the turbo with WD40 will do nothing to help the situation.
Here is a potential cause.
Having a series 2 your turbo has a bakerlight compressor wheel, a very hard plastic and this could be scuffing on the housing making a squeek or high pitch squeel.
It happens because the shaft wears out and usually there is forward/backward movement in the shaft causing it to push forward on the housing or backward on the backing plate.
It will eventually explode and throw bits of plastic all through your intake soon if the noise is in fact coming from the turbo.
Or you could have a bird in there that is opposed to greater boost pressures.
Kind of like a Nissan Nazi Budgie.
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522541
If anybody watched Top Gear on Monday night and saw the actor who drove the well priced car around the circuit and Clarkeson asking about a string of 911 Porches he had owned. As they were chatting about his string of cars he admitted he new bugger all about them and on one occasion was driving his brand new 944 he had picked up the day before, realising he didn't like it he stopped off at the Porche dealership and got another 911. He couldn't tell Clarkeson what model it was and the only one he could remember was the one he was actually driving to the interview. He couldn't even tell if any of them had been a turbo or RS or wide body.
My point ? If someone knows nothing about a particular car and still can't find the time to read enough to at least make some kind of considered opinion as to how it operates then does he deserve ownership ? Of course he does. That's what money is for. I wonder though why there are no longer any genuine GT Falcons left. GTR XU1's ? E49 chargers ? Because they, (like our Skylines will eventually be) were thrashed, crashed and neglected by people who never took five minute's to learn even the basics of maintainance before asking how their engine blew up. But hey, stuff it, it's just a bloody car after all. I shall now don my fire suit. Let the flaming begin.
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522564
returnaphonecallmuch?
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522620
Some funny replies there. My problem is, i bought a turbo off someone from the forums, put it on my car a few months back cause mine was f*ked and while changing it the gasket was kind of breaking but i had no way of getting another one because it was a public holiday.
So i used the original gasket. On sunday i had an exhaust leak which sounds like its coming from the gasket between the turbo and manifold. I bought the new gasket today and since half my stuff is out i thought i would spray wd40 in there to possibly help the squeak.
I wanted to know if it would hurt the turbo NOT fix it.
Oh and whats a flange?
Edited by WET-25T
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522698
the base of your turbine housing bolts the the FLANGE on your manifold. your manifold starts off with a flange, the item that mates agaisnt your head....
if metal flanges remind you of pussy, you are getting some bad pussy.... real bad
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522775
I sprayed about 0.00007 cents into it. Just the fro nt wheel, then wiped the remains away when it went to the bottom. Meh, im more annoyed that one of the studs came out of the manifold.
To save me the run around and because i need my car for work asap due to my boss not wanting to pick me up everyday, where can i get a new stud and nut?
Cheers
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4523250
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
