Checked your oil and made sure the pump is working? We were cruising around in a friends car and it started ticking pretty loudly, we thought nothing of it, then 5 minute later we had a seized engine.
Not meant to scare you, but better to be safe than sorry!
did it all of a sudden come on or has it been a gradual sort of noise over the months/years... It could be a noisy lifter so maybe u should give it an oil flush when changing oils, otherwise maybe it could be the oil pump? Either way i'd check it out asap as rebuilds aren't cool.
Guys,
try the old screwdriver test. What you do is get a long/large screwdriver, with the engine running, CAREFULLY place the blade of the screwdriver against various parts of the engine or on the components bolted to the engine and then place your ear against the butt end of the screwdriver and listen for excessive noises. If you're unsure how loud the noise should be check the same spot on a mates car. Good way to isolate a noise to a certain area.
JUST BE CAREFULL !!!
The NVCS solenoid on my car goes spastic every now and again. Makes a great clicking sound, sounds similar to a popcorn machine at full tilt. Just by holding the back of the solenoid where the plug goes into it stops it, just too lazy to fix this on a more permanent basis.
hahahaha i like ur style:D
the ticking whilst cold , as said above is the lack of oil in the top end so lifters will tick.
not too sure with skylines but in the vl , hydraulic lifters always after years of use seem to tick , and take a while to "pump up" when cold.
a water pump most likely wont make noise at idle , it is more a load thing , hold it at 3k revs , in neutral , and listen for a definate clunky noise , more evident than a tick noise.
sounds similar to a thrown big end bearing.
injectors make a constant tick tick tick , be it hot or cold , day or night.
injectors/lifters tick (probably a dupe but i cbf reading all the posts :()
mine does that fairly audible on idle with bonnet popped and head in engine bay, but if its from in the car whilst accelerating, more than likely u got a missing exhaust manifold bolt like me, dont worry about it unless it starts getting worse or the cars feeeling crap/doing something crappily noticeable :)
    • My fob has never worked, I once attempted to follow the procedure to re-key it, (I have other fobs for the car alarm thing in there). I actually have three of them. Do aftermarket alarms take over the pairing mechanism for central locking? Or do they piggyback off it? I suppose it depends on the system, right? I have four sets of keys/keyfobs. One definitely works, one I think works, one definitely doesn't work, and I have the OEM one that has never worked :p. Is this fixable/workable/whatever? I mean I know it's beyond "just clean it" but how *do* they get synced up?
    • It's actually a really weird comparison... the MX5 is on another level and I kinda question this comparison at all. It'd be closer to compare it to a GTI/Golf/Hatch anything that kicks around. NC MX5 with a turbo has the right to go up with and beat the FD RX7 or 180SX or any other JDM hero car. That's the comparison that would really ruffle feathers.
    • @MBS206 you need more shed in your life... What sort of car is your mates race car?  Hopefully he returns the favour when you're ready to get cracking on yours! None of my mates are into cars so I don't have to worry about that as a distraction thankfully.  I have enough other distractions so I don't need that one too!  Between working 6 days a week (5 1/2 really so 55 hours or so per week), both kids have basketball almost every week night (including Friday night in Melbourne - 2 hours away), my daughter plays netball as well, my sons footy has started now and I coach his under 14's side as well as I'm on the Footy club committee this year, I ride motorbikes every spare Sunday I can find, plus trying to be some sort of a husband.  Life is a busy little exercise at the moment!  I wish there were 8 or 9 days in a week sometimes!
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
