Im screwed!!!!
Got a letter a few weeks ago, I was in a shop, and mate comes in after 15 mins. He states to me cops been sitting behind my car for the past 10 mins. I was in a pickup/drop off park. Went out there and they were gone. Thought to myself. "Well, that went well." Got a letter in mail two weeks later stating my car was spotted driving in a particuliar street (load of shi..), and that the exhaust needed to be tested due to a certain police officer thinking it was 2 loud.
Fair enough. So went down to exhaust centre gave them a 2 1/2 muffler and said could U mount this and weld up half of the 2 1/2 inch pipe (3 1/2 inch into a 2 1/2 inch), to quiet it down enough. $260 later, did a great job. Went in got it tested 89 db. Woo Hoo passed. Got home removed muffler and put my bad boy muffler back on.
Mrs borrows the car! The other day to get to work, guess what! Yes, massive police blitz on Calder Highway on incomming side of Bendigo. Get the phone call from Mrs. "They about to do a EPA noise test on your car." Not good! Got a reading of 113 db!icon8.gif
They didn't know the car had just been through a test a gathered. They didn't ask her about it, but stated that I would be getting a fine maybe in the mail. I gather I will, not to sure how BIG yet. Heard a bloke got $2500 fine fore removing his CAT's. I will eventually get through this in the end.
Just to make things worse, my clutch shi... itself today (nismo twin-plate spring button clutch) done a hole 15,000 khms since it got re-conditioned. <------------DODGY AS!icon7.gif
Anyone had this happen to them before, or simular. Any advice would be muchly appreciated.
WHITEBEAST.
https://www.sau.com.au/forums/topic/264551-the-epa/
Im screwed!!!!
WHITEBEAST.
im sorry to hear your unfortunate event....
look, the BEST thing for you.....is just, deal with things as they come.....
sometimes people tend to OVER-worry & in the end, nothing.
it really depends on your luck, im sure your not the only one in Aust with an illegal exhaust.
well the fine for removing cat, i recall is double that price you mentioned....
years ago, ive had a TT supra which i removed the cat & tested at 135db & never been defected in a 3 year period.
the only thing you can do, is to wack the quiet one on... and get it tested if you are summoned.
because the Cops can be faulty with thier testing....
so that way the only thing you can say, is that the coppers didnt test properly.
good luck
https://www.sau.com.au/forums/topic/264551-the-epa/#findComment-4522585
good luck
Might be onto something there.
Going to just have to see where it all ends up, done my share of stressing about it.
I think the way the police are going with all these new laws these days. Is to run an illegal shutter valve in the exhaust when cruising around town and when you see these Police Blitz. (hope they don't see it).icon2.gif
https://www.sau.com.au/forums/topic/264551-the-epa/#findComment-4522684
like i said, if they summon you to be tested, it may be no big deal.
police are known to be faulty with tests. Some say the Db Meter has to be a foot away from the exhaust... others say it has to be a metre away. And ive heard of encounters with police having the Db right on the tip of the muffler.
thats why Random breath tests, if you are positive... they take you away and test you properly at the cop shop.
because sometimes foods can give it a false reading.
yeah no point stressing...
https://www.sau.com.au/forums/topic/264551-the-epa/#findComment-4522943
just went thru this last week
bit of a bitch and a waste of time and cash though
at least ur helping the economy in this tough time lol
hmm
seems like cops are really cracking down on defective cars lately and the Skylines are an easy target
https://www.sau.com.au/forums/topic/264551-the-epa/#findComment-4526562
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
