hey everyone im new on this so yep its my first time on this forum. i have an issue with my skyline with the head lights cover that its very dirty and has foggy stains from the insides of the head light cover, im just wondering how do i get rid of and clean it. i tried to see if you can take of the head light cover but i think its just one big piece and you cant. so if can somebody help me thats would be excellent
Edited by twinz
assuming it is similar to the 32 headlight. And I think it should be.
You can put it in the oven (seriously). What I did when I had to open my headlight was.
- Put aluminum foil in tray/grill
- Pre-heat the oven to 180c (without the headlight in it)
- TURN OVERN OFF
- Place headlight in the tray for approximately 5 mins
- The sealant should be soft enough for you to open up the headlight using a screw driver.
Now, there is probabaly some clips holding the over on the outside, so be sure to remove those 1st before you put in the oven. Also besure to remove all the wire and globe...etc
- TURN OVERN OFF
whats the best way to take the headlights off without breaking the clips that hold the lights in place.....
ever heard of a search ?
well
this person is new and could be eager to know something ...too eager to do a search perhaps.....
saying "search" isnt being helpful as well...
as for the headlight
there are products to clean it. but with plastic......you will notice that there might be hairline cracks when you look at it in the light.
Edited by eeiko321
there are no cracks in the head light thats 100% so ill try the plastic cleaner for sure and give that a go and will see what happens... hopefully that will fix the foggy headlights cross fingers.
its on the outside... we do it at work all day every day
we make them come up literally as good as theyll ever get which is damn good!!!!
do not put them in the oven theyre totally different to r32 as what as has been suggested above
well ive found the plastic polish always works.... but like i said...look very very closely in broad day light. sometimes you could see very very fine cracks. and Generally dirty headlights always have them.
if by any chance it doesnt work, there was a mob in Windsor whom glazes headlights and could mould it via the plastic one you have...
because with glass you actually dont lose any % of light
what do you guys use to clean up the head lights. what solution...
do you know the details of the mobb in Windsor by any chance
i use an RO polisher with paint polish to correct my headlights.
Edge green pad with Menzerna IP 3.01 does the trick.
If you have access to someone who can detail cars, just mask up around the headlight and polish it with a machine and paint polish.
get mcguires plast-x and scrub the hell out of the outsides.... you'll be surprised what this stuff can do
That's what I used on mine, came up like new in literally minutes.
I initially thought mine were dirty on the inside too, not the case however.
so all you did was just use a rag and the plastic polish and scrub the hell out of it was it...
From the latest HPI magazine (No. 106) there is an article on the exact thing you're after I believe.
I have scanned the page. Sorry if it's hard to read, it was a large image when I uploaded it but photobucket must have down-sized it.
Hope that helped,
-Jimmy.
Edited by -Jimmy-
unfortunately i dont
this was years ago... look up glass glaziers...
some of them can actually mould a shape if you can send them the plastic headlight
give the polish a try...
i recall there was a comparison test with plastic vs glass in headlights and plastic aftermarket headlight shields sold, particularly for off road 4wds... and with plastic.. 5% of light is actually lost.
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
