If you are experiencing problems with your heater control IE:
All of a sudden getting blasts of hot air while driving?
Can you hear a buzzing in the centre of the dash even with the climate control off?
Generally strange operation of the climate control system.
I have a free way to solve the problem as long as your mechanically minded, etc.
If there is enough interest i'll create a DIY on it.
Deren
P.S - This same fix could possibly extend to other nissan models but im not 100% sure they use the same component.
https://www.sau.com.au/forums/topic/264605-r32s13-climate-control-problems/
Have you run the diagnostic on the climate control system? If not all you need to do to enter self diagnostics is hold down the 'off' button for a few seconds within about 5 seconds of turning the ignition on. From there you use the hot and cold buttons to cycle through the different tests.
Sounds like it will be the heater tap servo to blae though. Unless there is a problem with the heater core itself or the hoses to it. Did it work previously since owning the car?
Deren
